Re: REW [Room EQ Wizard] Tips
House Curve examples and how to load them into REW...
To understand what a house curve is, and why you might want one, there are two excellent threads on the subject
here and
here.
Below are some examples to load into REW.
Which house curve you use is totally up to you... you might try different house curves in different presets on the BFD, playing back your favorite bass scenes over and over for the various house curves and determining which one you like best.
The house curve is easily created in Notepad and saved to a folder on your hard drive as a text file.
Here's an example of what one house curve would look like in Notepad:
The file simply says that the house curve will begin at 80Hz and that +8dB will be added to the normal REW target curve by 30Hz.
You can save it and name it whatever you wish. I have them named house.txt, house2.txt, house3.txt... etc.
Once you have saved the file you load it in REW by first selecting the Settings button in REW and then select the House Curve tab. It is then as simple as browsing to the location in your computer where you saved your file.
Here is a typical target line in REW with no house curve applied:
The following is a house curve suggested by brucek:
Text file:
30 8.0
80 0.0
If you don't like the humped nature of the line drawn between 80Hz and 30Hz (for example), you may check the Logarithmic extrapolation checkbox and the line will become much straighter. The longer the line, the more noticable it becomes.
This is one suggested by Ayreonaut:
Text file:
31.5 0
36 -1.25
40 -2.5
45 -3.75
50 -5
56 -6.25
63 -7.5
71 -8.75
80 -10
89 -11.25
100 -12.5
111 -13.75
125 -15
142.5 -16.25
160 -17.5
Here's another:
Text file:
30 5.0
100 0.0
Here's one more:
Text file:
30 10.0
100 0.0
If you have a suggested house curve that you would like added, please post them here.
