1 - 2 of 2 Posts
I installed an audio equalizer from sourceforge, then it said that I need to install REW to use it. To install REW I had to join this forum...
I thought this all looked like it might be worth the round-about things I had to do to try it, so now I tried to install it.
I started the REW install and it is trying to install what appears to be 32-bit Java. I already have the 64-bit Java environment installed.
Is this really necessary? Is there a way around that? Won't installing 32-bit Java interfere with the already installed 64-bit Java?
Thanks in advance for any help on this!
The Windows installer needs a 32-bit JRE (or seems to). You can have both 32 and 64 bit installations on the same machine.
1 - 2 of 2 Posts
