Process: JavaApplicationStub [2912]
Path: /Applications/RoomEQWizardV5Beta.app/Contents/MacOS/JavaApplicationStub
Identifier: com.apple.javajdk16.Room EQ Wizard
Version: ??? (5.0 Beta)
Code Type: X86 (Native)
Parent Process: launchd [81]
Date/Time: 2010-05-02 12:15:44.795 +0200
OS Version: Mac OS X 10.6.3 (10D573)
Report Version: 6
Interval Since Last Report: 370443 sec
Crashes Since Last Report: 5
Per-App Interval Since Last Report: 55 sec
Per-App Crashes Since Last Report: 5
Anonymous UUID: 559886C9-0530-44E5-B952-9B3F8516C0CC
Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000
Crashed Thread: 3
Application Specific Information:
Java information:
Exception type: Bus Error (0xa) at pc=0x95054080
Java VM: Java HotSpot(TM) Client VM (14.3-b01-101 mixed mode, sharing macosx-x86)
Current thread (0x02800400): JavaThread "main" [_thread_in_native, id=-1332719616, stack(0xb0105000,0xb0905000)]
Stack: [0xb0105000,0xb0905000]
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j com.sun.media.sound.MidiInDeviceProvider.nGetName(I)Ljava/lang/String;+0
j com.sun.media.sound.MidiInDeviceProvider.access$100(I)Ljava/lang/String;+1
j com.sun.media.sound.MidiInDeviceProvider$MidiInDeviceInfo.<init>(ILjava/lang/Class;)V+2
j com.sun.media.sound.MidiInDeviceProvider$MidiInDeviceInfo.<init>(ILjava/lang/Class;Lcom/sun/media/sound/MidiInDeviceProvider$1;)V+3
j com.sun.media.sound.MidiInDeviceProvider.createInfo(I)Lcom/sun/media/sound/AbstractMidiDeviceProvider$Info;+17
j com.sun.media.sound.AbstractMidiDeviceProvider.readDeviceInfos()V+101
j com.sun.media.sound.AbstractMidiDeviceProvider.getDeviceInfo()[Ljavax/sound/midi/MidiDevice$Info;+1
j javax.sound.midi.MidiSystem.getMidiDeviceInfo()[Ljavax/sound/midi/MidiDevice$Info;+36
j roomeqwizard.qB.B()V+12
j roomeqwizard.qB.A(Ljava/lang/String;)Z+0
j roomeqwizard.RoomEQ_Wizard.B()V+219
j roomeqwizard.RoomEQ_Wizard.main([Ljava/lang/String;)V+91
v ~StubRoutines::call_stub
j sun.reflect.NativeMethodAccessorImpl.invoke0(Ljava/lang/reflect/Method;Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+0
j sun.reflect.NativeMethodAccessorImpl.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+87
j sun.reflect.DelegatingMethodAccessorImpl.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+6
j java.lang.reflect.Method.invoke(Ljava/lang/Object;[Ljava/lang/Object;)Ljava/lang/Object;+161
j apple.launcher.LaunchRunner.run()V+76
j apple.launcher.LaunchRunner.callMain()V+1
j apple.launcher.JavaApplicationLauncher.launch(JJZ)V+11
Java Threads: ( => current thread )
0x02016400 JavaThread "Image Fetcher 1" daemon [_thread_blocked, id=-1316831232, stack(0xb172c000,0xb182c000)]
0x02015400 JavaThread "Timer-0" daemon [_thread_blocked, id=-1317888000, stack(0xb162a000,0xb172a000)]
0x02013800 JavaThread "TimerQueue" daemon [_thread_blocked, id=-1318944768, stack(0xb1528000,0xb1628000)]
0x0287a400 JavaThread "AWT-EventQueue-0" [_thread_blocked, id=-1320001536, stack(0xb1426000,0xb1526000)]
0x02038400 JavaThread "Image Fetcher 0" daemon [_thread_blocked, id=-1321058304, stack(0xb1324000,0xb1424000)]
0x02033400 JavaThread "Java2D Disposer" daemon [_thread_blocked, id=-1322115072, stack(0xb1222000,0xb1322000)]
0x02873400 JavaThread "AWT-Shutdown" [_thread_blocked, id=-1323208704, stack(0xb1117000,0xb1217000)]
0x02873000 JavaThread "AWT-AppKit" daemon [_thread_in_native, id=-1606392608, stack(0xbf800000,0xc0000000)]
0x02011000 JavaThread "Low Memory Detector" daemon [_thread_blocked, id=-1325322240, stack(0xb0f13000,0xb1013000)]
0x0200fc00 JavaThread "CompilerThread0" daemon [_thread_blocked, id=-1326379008, stack(0xb0e11000,0xb0f11000)]
0x02811800 JavaThread "Signal Dispatcher" daemon [_thread_blocked, id=-1327435776, stack(0xb0d0f000,0xb0e0f000)]
0x0200e400 JavaThread "Finalizer" daemon [_thread_blocked, id=-1328492544, stack(0xb0c0d000,0xb0d0d000)]
0x0200d800 JavaThread "Reference Handler" daemon [_thread_blocked, id=-1329549312, stack(0xb0b0b000,0xb0c0b000)]
=>0x02800400 JavaThread "main" [_thread_in_native, id=-1332719616, stack(0xb0105000,0xb0905000)]
Other Threads:
0x0280fc00 VMThread [stack: 0xb0a09000,0xb0b09000] [id=-1330606080]
0x02812400 WatcherThread [stack: 0xb1015000,0xb1115000] [id=-1324265472]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
def new generation total 1664K, used 271K [0x0d010000, 0x0d1e0000, 0x0f770000)
eden space 1472K, 5% used [0x0d010000, 0x0d023f68, 0x0d180000)
from space 192K, 100% used [0x0d180000, 0x0d1b0000, 0x0d1b0000)
to space 192K, 0% used [0x0d1b0000, 0x0d1b0000, 0x0d1e0000)
tenured generation total 22720K, used 2803K [0x0f770000, 0x10da0000, 0x2d010000)
the space 22720K, 12% used [0x0f770000, 0x0fa2cc18, 0x0fa2ce00, 0x10da0000)
compacting perm gen total 12288K, used 619K [0x2d010000, 0x2dc10000, 0x31010000)
the space 12288K, 5% used [0x2d010000, 0x2d0aaee0, 0x2d0ab000, 0x2dc10000)
ro space 8192K, 91% used [0x31010000, 0x31766f08, 0x31767000, 0x31810000)
rw space 12288K, 74% used [0x31810000, 0x3210ead0, 0x3210ec00, 0x32410000)
Virtual Machine Arguments:
JVM Args: -Xbootclasspath/a:/System/Library/PrivateFrameworks/JavaApplicationLauncher.framework/Resources/LauncherSupport.jar -Xms24mm -Xmx512mm -Dapple.laf.useScreenMenuBar=true
Java Command: <unknown>
Launcher Type: generic
Physical Memory: Page Size = 4k, Total = 1024M, Free = 113M
Thread 0: Dispatch queue: com.apple.main-thread
0 libSystem.B.dylib 0x930cd2fa mach_msg_trap + 10
1 libSystem.B.dylib 0x930cda67 mach_msg + 68
2 com.apple.CoreFoundation 0x9508200f __CFRunLoopRun + 2079
3 com.apple.CoreFoundation 0x950810f4 CFRunLoopRunSpecific + 452
4 com.apple.CoreFoundation 0x95080f21 CFRunLoopRunInMode + 97
5 com.apple.HIToolbox 0x965740fc RunCurrentEventLoopInMode + 392
6 com.apple.HIToolbox 0x96573eb1 ReceiveNextEventCommon + 354
7 com.apple.HIToolbox 0x96573d36 BlockUntilNextEventMatchingListInMode + 81
8 com.apple.AppKit 0x95c74135 _DPSNextEvent + 847
9 com.apple.AppKit 0x95c73976 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 156
10 com.apple.AppKit 0x95c35bef -[NSApplication run] + 821
11 libawt.jnilib 0x053aedfa +[AWTStarter startAWT:] + 1706
12 libawt.jnilib 0x0536c727 -[CPerformer perform] + 243
13 com.apple.Foundation 0x977e2de5 __NSThreadPerformPerform + 506
14 com.apple.CoreFoundation 0x9508415b __CFRunLoopDoSources0 + 1563
15 com.apple.CoreFoundation 0x95081c1f __CFRunLoopRun + 1071
16 com.apple.CoreFoundation 0x950810f4 CFRunLoopRunSpecific + 452
17 com.apple.CoreFoundation 0x95080f21 CFRunLoopRunInMode + 97
18 ...ple.JavaApplicationLauncher 0x0000858e startupJava(LauncherArgsStruct*) + 342
19 ...ple.JavaApplicationLauncher 0x000078cf launchJavaApplication + 1355
20 JavaApplicationStub 0x00001e8e 0x1000 + 3726
21 JavaApplicationStub 0x00001cf0 0x1000 + 3312
22 JavaApplicationStub 0x00001c1d 0x1000 + 3101
Thread 1: Dispatch queue: com.apple.libdispatch-manager
0 libSystem.B.dylib 0x930f3b42 kevent + 10
1 libSystem.B.dylib 0x930f425c _dispatch_mgr_invoke + 215
2 libSystem.B.dylib 0x930f3719 _dispatch_queue_invoke + 163
3 libSystem.B.dylib 0x930f34be _dispatch_worker_thread2 + 240
4 libSystem.B.dylib 0x930f2f41 _pthread_wqthread + 390
5 libSystem.B.dylib 0x930f2d86 start_wqthread + 30
Thread 2:
0 libSystem.B.dylib 0x930f2bd2 __workq_kernreturn + 10
1 libSystem.B.dylib 0x930f3168 _pthread_wqthread + 941
2 libSystem.B.dylib 0x930f2d86 start_wqthread + 30
Thread 3 Crashed:
0 com.apple.CoreFoundation 0x95054080 CFStringGetCStringPtr + 128
1 libjsound.jnilib 0x0824eeea Java_com_sun_media_sound_HAEShutdownHook_createNativeRef + 3284
2 libjsound.jnilib 0x0824f02e Java_com_sun_media_sound_HAEShutdownHook_createNativeRef + 3608
3 libjsound.jnilib 0x0824f159 Java_com_sun_media_sound_HAEShutdownHook_createNativeRef + 3907
4 libjsound.jnilib 0x0824f3b5 Java_com_sun_media_sound_HAEShutdownHook_createNativeRef + 4511
5 libjsound.jnilib 0x0824fe79 Java_com_sun_media_sound_MidiInDeviceProvider_nGetName + 63
6 ??? 0x0300b839 0 + 50378809
7 ??? 0x03003f17 0 + 50347799
8 ??? 0x03003f17 0 + 50347799
9 ??? 0x03003db1 0 + 50347441
10 ??? 0x03003db1 0 + 50347441
11 ??? 0x03003f17 0 + 50347799
12 ??? 0x03003db1 0 + 50347441
13 ??? 0x03003f17 0 + 50347799
14 ??? 0x03003f17 0 + 50347799
15 ??? 0x03003db1 0 + 50347441
16 ??? 0x03003fdd 0 + 50347997
17 ??? 0x03003db1 0 + 50347441
18 ??? 0x030012d3 0 + 50336467
19 libclient.dylib 0x018a57d0 JVM_Lseek + 149024
20 libclient.dylib 0x018a5576 JVM_Lseek + 148422
21 libclient.dylib 0x018a5546 JVM_Lseek + 148374
22 libclient.dylib 0x018c7fe8 JVM_NewInstanceFromConstructor + 3896
23 libclient.dylib 0x018c9bde JVM_InvokeMethod + 1342
24 libclient.dylib 0x018c9892 JVM_InvokeMethod + 498
25 libjava.jnilib 0x0009916a Java_sun_reflect_NativeMethodAccessorImpl_invoke0 + 38
26 ??? 0x0300b839 0 + 50378809
27 ??? 0x03003f17 0 + 50347799
28 ??? 0x03003f17 0 + 50347799
29 ??? 0x030043f3 0 + 50349043
30 ??? 0x03003f17 0 + 50347799
31 ??? 0x03003db1 0 + 50347441
32 ??? 0x03003db1 0 + 50347441
33 ??? 0x030012d3 0 + 50336467
34 libclient.dylib 0x018a57d0 JVM_Lseek + 149024
35 libclient.dylib 0x018a5576 JVM_Lseek + 148422
36 libclient.dylib 0x018a5546 JVM_Lseek + 148374
37 libclient.dylib 0x018d6051 JVM_FindLoadedClass + 3441
38 libclient.dylib 0x0190ec02 JVM_Socket + 5170
39 ...ple.JavaApplicationLauncher 0x00009c12 JNIEnv_::CallStaticVoidMethod(_jclass*, _jmethodID*, ...) + 44
40 ...ple.JavaApplicationLauncher 0x0000947b startJavaApplication + 3627
41 ...ple.JavaApplicationLauncher 0x0000864e runJava(LauncherArgsStruct*) + 78
42 ...ple.JavaApplicationLauncher 0x000085f8 java_main_stub(void*) + 22
43 libSystem.B.dylib 0x930faa19 _pthread_start + 345
44 libSystem.B.dylib 0x930fa89e thread_start + 34
Thread 4: Java: Exception Handler Thread
2 libSystem.B.dylib 0x93139048 mach_msg_server + 520
3 libclient.dylib 0x0180fe25 JNI_CreateJavaVM_Impl + 61045
4 libclient.dylib 0x0180fdca JNI_CreateJavaVM_Impl + 60954
5 libclient.dylib 0x0180e33b JNI_CreateJavaVM_Impl + 54155
6 libSystem.B.dylib 0x930faa19 _pthread_start + 345
7 libSystem.B.dylib 0x930fa89e thread_start + 34
Thread 5: Java: VM Thread
2 libclient.dylib 0x0180f037 JNI_CreateJavaVM_Impl + 57479
3 libclient.dylib 0x0182bbb0 jio_vsnprintf + 29632
4 libclient.dylib 0x0180e9b7 JNI_CreateJavaVM_Impl + 55815
5 libclient.dylib 0x0180e588 JNI_CreateJavaVM_Impl + 54744
6 libclient.dylib 0x018a3f5b JVM_Lseek + 142763
7 libclient.dylib 0x018a3c8a JVM_Lseek + 142042
8 libclient.dylib 0x0180e33b JNI_CreateJavaVM_Impl + 54155
9 libSystem.B.dylib 0x930faa19 _pthread_start + 345
10 libSystem.B.dylib 0x930fa89e thread_start + 34
Thread 6: Java: Reference Handler
2 libclient.dylib 0x0180ef23 JNI_CreateJavaVM_Impl + 57203
3 libclient.dylib 0x0180edab JNI_CreateJavaVM_Impl + 56827
4 libclient.dylib 0x018b8c95 JVM_MonitorWait + 5461
5 libclient.dylib 0x018b7bfe JVM_MonitorWait + 1214
6 libclient.dylib 0x018b787a JVM_MonitorWait + 314
7 ??? 0x0300b839 0 + 50378809
8 ??? 0x03003db1 0 + 50347441
10 ??? 0x030012d3 0 + 50336467
11 libclient.dylib 0x018a57d0 JVM_Lseek + 149024
12 libclient.dylib 0x018a5576 JVM_Lseek + 148422
13 libclient.dylib 0x018b711b JVM_InternString + 2123
14 libclient.dylib 0x018b6f8a JVM_InternString + 1722
15 libclient.dylib 0x018b6d74 JVM_InternString + 1188
16 libclient.dylib 0x018b680f JVM_StartThread + 2175
17 libclient.dylib 0x0180e33b JNI_CreateJavaVM_Impl + 54155
18 libSystem.B.dylib 0x930faa19 _pthread_start + 345
19 libSystem.B.dylib 0x930fa89e thread_start + 34
Thread 7: Java: Finalizer
9 ??? 0x03003f17 0 + 50347799
10 ??? 0x03003f17 0 + 50347799
11 ??? 0x030012d3 0 + 50336467
12 libclient.dylib 0x018a57d0 JVM_Lseek + 149024
13 libclient.dylib 0x018a5576 JVM_Lseek + 148422
14 libclient.dylib 0x018b711b JVM_InternString + 2123
15 libclient.dylib 0x018b6f8a JVM_InternString + 1722
16 libclient.dylib 0x018b6d74 JVM_InternString + 1188
17 libclient.dylib 0x018b680f JVM_StartThread + 2175
18 libclient.dylib 0x0180e33b JNI_CreateJavaVM_Impl + 54155
19 libSystem.B.dylib 0x930faa19 _pthread_start + 345
20 libSystem.B.dylib 0x930fa89e thread_start + 34
Thread 8: Java: Signal Dispatcher
0 libSystem.B.dylib 0x930cd336 semaphore_wait_trap + 10
1 libclient.dylib 0x018ceb5e JVM_IsPrimitiveClass + 10398
2 libclient.dylib 0x018ce92e JVM_IsPrimitiveClass + 9838
3 libclient.dylib 0x018b6d74 JVM_InternString + 1188
4 libclient.dylib 0x018b680f JVM_StartThread + 2175
Thread 9: Java: CompilerThread0
4 libclient.dylib 0x0180e928 JNI_CreateJavaVM_Impl + 55672
5 libclient.dylib 0x0180e4a9 JNI_CreateJavaVM_Impl + 54521
6 libclient.dylib 0x018cfec2 JVM_IsPrimitiveClass + 15362
7 libclient.dylib 0x018cfc9b JVM_IsPrimitiveClass + 14811
8 libclient.dylib 0x018b6d74 JVM_InternString + 1188
9 libclient.dylib 0x018b680f JVM_StartThread + 2175
10 libclient.dylib 0x0180e33b JNI_CreateJavaVM_Impl + 54155
11 libSystem.B.dylib 0x930faa19 _pthread_start + 345
12 libSystem.B.dylib 0x930fa89e thread_start + 34
Thread 10: Java: Low Memory Detector
6 libclient.dylib 0x018d3e32 JVM_IsPrimitiveClass + 31602
7 libclient.dylib 0x018b6d74 JVM_InternString + 1188
8 libclient.dylib 0x018b680f JVM_StartThread + 2175
9 libclient.dylib 0x0180e33b JNI_CreateJavaVM_Impl + 54155
10 libSystem.B.dylib 0x930faa19 _pthread_start + 345
11 libSystem.B.dylib 0x930fa89e thread_start + 34
Thread 11: Java: VM Periodic Task Thread
3 libclient.dylib 0x018d510d JVM_IsPrimitiveClass + 36429
4 libclient.dylib 0x018d4d5d JVM_IsPrimitiveClass + 35485
Thread 12: Java: AWT-Shutdown
10 ??? 0x0300428d 0 + 50348685
Thread 13: Java: Java2D Disposer
11 ??? 0x0300428d 0 + 50348685
12 ??? 0x030012d3 0 + 50336467
13 libclient.dylib 0x018a57d0 JVM_Lseek + 149024
14 libclient.dylib 0x018a5576 JVM_Lseek + 148422
15 libclient.dylib 0x018b711b JVM_InternString + 2123
16 libclient.dylib 0x018b6f8a JVM_InternString + 1722
17 libclient.dylib 0x018b6d74 JVM_InternString + 1188
18 libclient.dylib 0x018b680f JVM_StartThread + 2175
19 libclient.dylib 0x0180e33b JNI_CreateJavaVM_Impl + 54155
20 libSystem.B.dylib 0x930faa19 _pthread_start + 345
21 libSystem.B.dylib 0x930fa89e thread_start + 34
Thread 14: Java: Image Fetcher 0
4 libclient.dylib 0x018b88a8 JVM_MonitorWait + 4456
Thread 15: Java: AWT-EventQueue-0
11 ??? 0x03003fdd 0 + 50347997
13 ??? 0x03003db1 0 + 50347441
14 ??? 0x03003db1 0 + 50347441
16 ??? 0x030012d3 0 + 50336467
17 libclient.dylib 0x018a57d0 JVM_Lseek + 149024
18 libclient.dylib 0x018a5576 JVM_Lseek + 148422
19 libclient.dylib 0x018b711b JVM_InternString + 2123
20 libclient.dylib 0x018b6f8a JVM_InternString + 1722
21 libclient.dylib 0x018b6d74 JVM_InternString + 1188
22 libclient.dylib 0x018b680f JVM_StartThread + 2175
23 libclient.dylib 0x0180e33b JNI_CreateJavaVM_Impl + 54155
24 libSystem.B.dylib 0x930faa19 _pthread_start + 345
25 libSystem.B.dylib 0x930fa89e thread_start + 34
Thread 16: Java: TimerQueue
9 ??? 0x0300428d 0 + 50348685
Thread 17: Java: Timer-0
Thread 18: Java: Image Fetcher 1
Thread 19:
2 com.apple.audio.midi.CoreMIDI 0x0826cf31 XServerMachPort::ReceiveMessage(int&, void*, int&) + 155
3 com.apple.audio.midi.CoreMIDI 0x0828b8fe MIDIProcess::RunMIDIInThread() + 150
4 com.apple.audio.midi.CoreMIDI 0x0826e149 XThread::RunHelper(void*) + 17
5 com.apple.audio.midi.CoreMIDI 0x0826db16 CAPThread::Entry(CAPThread*) + 96
Thread 3 crashed with X86 Thread State (32-bit):
eax: 0xa06088cc ebx: 0x9505400d ecx: 0x00000000 edx: 0x00000007
edi: 0x00000000 esi: 0x00000000 ebp: 0xb0903d38 esp: 0xb0903d20
ss: 0x0000001f efl: 0x00010283 eip: 0x95054080 cs: 0x00000017
ds: 0x0000001f es: 0x0000001f fs: 0x0000001f gs: 0x00000037
cr2: 0x00000000
Binary Images:
0x1000 - 0x1fff +JavaApplicationStub ??? (5.0 Beta) <1B85C136-50A3-B8BD-6251-D4354B9E4178> /Applications/RoomEQWizardV5Beta.app/Contents/MacOS/JavaApplicationStub
0x6000 - 0x10ff7 com.apple.JavaApplicationLauncher 13.1.0 (13.1.0) <4AC23F10-15F8-A81C-A1A0-89FA16CC14FB> /System/Library/PrivateFrameworks/JavaApplicationLauncher.framework/Versions/A/JavaApplicationLauncher
0x18000 - 0x1fff7 com.apple.JavaVM 13.1.0 (13.1.0) <2842C4EE-869D-81E6-E771-062F583A1044> /System/Library/Frameworks/JavaVM.framework/Versions/A/JavaVM
0x76000 - 0x7eff7 libverify.dylib 1.0 (1.0) <0E0C6835-68C5-A72F-8CA0-77857B632513> /System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Libraries/libverify.dylib
0x83000 - 0x8aff7 JavaNativeFoundation ??? (???) <1107BBC2-DFC1-CF1F-44EE-27F7D4349BE6> /System/Library/Frameworks/JavaVM.framework/Versions/A/Frameworks/JavaNativeFoundation.framework/Versions/A/JavaNativeFoundation
0x93000 - 0xb0ff7 libjava.jnilib ??? (???) <C4C57812-6A25-85AB-441B-DE1A71A8DF18> /System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Libraries/libjava.jnilib
0xcd000 - 0xd9ff7 libzip.jnilib ??? (???) <1317EACC-2494-70C3-4B43-FC9D04579EAF> /System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Libraries/libzip.jnilib
0x7f8000 - 0x7f9ff7 liblauncher.jnilib ??? (???) <10117357-AD34-E263-4132-902438F8C368> /System/Library/PrivateFrameworks/JavaApplicationLauncher.framework/Versions/A/Resources/liblauncher.jnilib
0x1800000 - 0x1bf6fe7 libclient.dylib ??? (???) <6B8B4A7E-2844-3AD6-239E-122121D37485> /System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Libraries/libclient.dylib
0x1cce000 - 0x1cd1fe7 com.apple.java.JavaRuntimeSupport 13.1.0 (13.1.0) <70CFA5B6-4FFA-8EFB-E4CE-202B0B9A4DB6> /System/Library/Frameworks/JavaVM.framework/Versions/A/Frameworks/JavaRuntimeSupport.framework/Versions/A/JavaRuntimeSupport
0x5366000 - 0x5528ff7 libawt.jnilib ??? (???) <FF31ED82-3BB5-A05D-3B83-35E11590E529> /System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Libraries/libawt.jnilib
0x714a000 - 0x714dff7 liblaf.jnilib ??? (???) <373D235D-3372-814D-DDB5-11C1C750A48B> /System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Libraries/liblaf.jnilib
0x8226000 - 0x8253ff7 libjsound.jnilib ??? (???) <9CC0EB06-925C-32F7-E9C1-ABAC838C39C1> /System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Libraries/libjsound.jnilib
0x825d000 - 0x82a9fff com.apple.audio.midi.CoreMIDI 1.7 (42) <670CB7F9-AA00-86F3-6623-E1335F7AEA83> /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0xab09000 - 0xab6cff7 libfontmanager.jnilib ??? (???) <78446877-99AA-82F5-8509-0281A5740A47> /System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Libraries/libfontmanager.jnilib
0xab83000 - 0xaba5ff7 libjpeg.jnilib ??? (???) <32233A65-09F0-434C-D616-64946CFEB3C0> /System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Libraries/libjpeg.jnilib
0xabca000 - 0xabd7ff7 libnet.jnilib ??? (???) <E14CEE5F-42DC-9727-6A3E-FE25EAFFB423> /System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Libraries/libnet.jnilib
0xabdd000 - 0xabe0ff7 libnio.jnilib ??? (???) <6AE890EE-BB11-6931-EEBF-01AE9D682E3F> /System/Library/Frameworks/JavaVM.framework/Versions/1.6.0/Libraries/libnio.jnilib
0x8fe00000 - 0x8fe4162b dyld 132.1 (???) <211AF0DD-42D9-79C8-BB6A-1F4BEEF4B4AB> /usr/lib/dyld
0x90003000 - 0x907f2537 com.apple.CoreGraphics 1.543.33 (???) <C57E2964-80AF-6346-6D3E-23AED9D26977> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x90815000 - 0x90825ff7 libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) <C8744EA3-0AB7-CD03-E639-C4F2B910BE5D> /usr/lib/libsasl2.2.dylib
0x90895000 - 0x908a9ffb com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <57DD5458-4F24-DA7D-0927-C3321A65D743> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x908aa000 - 0x9092afeb com.apple.SearchKit 1.3.0 (1.3.0) <9E18AEA5-F4B4-8BE5-EEA9-818FC4F46FD9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x90986000 - 0x909a1ff7 libPng.dylib ??? (???) <929FE8EE-277D-F6EB-D672-E6F4CEBF1504> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x909cf000 - 0x90a02ff7 com.apple.AE 496.4 (496.4) <7F34EC47-8429-3077-8158-54F5EA908C66> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x90a03000 - 0x90a67ffb com.apple.htmlrendering 72 (1.1.4) <4D451A35-FAB6-1288-71F6-F24A4B6E2371> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x90a68000 - 0x90a80ff7 com.apple.CFOpenDirectory 10.6 (10.6) <1537FB4F-C112-5D12-1E5D-3B1002A4038F> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x90a81000 - 0x90a95fe7 libbsm.0.dylib ??? (???) <14CB053A-7C47-96DA-E415-0906BA1B78C9> /usr/lib/libbsm.0.dylib
0x90a96000 - 0x90ecbff7 libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <5E2D2283-57DE-9A49-1DB0-CD027FEFA6C2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x90ecc000 - 0x90f15fe7 libTIFF.dylib ??? (???) <E45B169E-253E-E865-1501-97777D2702F2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x90f57000 - 0x90f61ffb com.apple.speech.recognition.framework 3.11.1 (3.11.1) <EC0E69C8-A121-70E8-43CF-E6FC4C7779EC> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x90f62000 - 0x9111eff3 com.apple.ImageIO.framework 3.0.2 (3.0.1) <CB39B067-58B8-70DB-3E40-160604664A6D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x9111f000 - 0x91161ff7 libvDSP.dylib 268.0.1 (compatibility 1.0.0) <3F0ED200-741B-4E27-B89F-634B131F5E9E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x9119b000 - 0x9119fff7 libGFXShared.dylib ??? (???) <286F466C-2856-B579-B87F-4E9A35C80263> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x9120a000 - 0x912a2fe7 edu.mit.Kerberos 6.5.9 (6.5.9) <73EC847F-FF44-D542-2AD5-97F6C8D48F0B> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x912a3000 - 0x91312ff7 libvMisc.dylib 268.0.1 (compatibility 1.0.0) <2FC2178F-FEF9-6E3F-3289-A6307B1A154C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x91313000 - 0x91316ffb com.apple.help 1.3.1 (41) <67F1F424-3983-7A2A-EC21-867BE838E90B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x91317000 - 0x91317ff7 com.apple.vecLib 3.6 (vecLib 3.6) <7362077A-890F-3AEF-A8AB-22247B10E106> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x9165f000 - 0x9165fff7 com.apple.ApplicationServices 38 (38) <8012B504-3D83-BFBB-DA65-065E061CFE03> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x91660000 - 0x9173bfe7 com.apple.DesktopServices 1.5.5 (1.5.5) <ECEDFDF2-C40E-8DF0-F8FC-249CCA762E62> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x91a32000 - 0x91a44ff7 com.apple.MultitouchSupport.framework 204.12.1 (204.12.1) <6BB58E90-21FA-C491-F0E4-54B69CCDBBC0> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x91a45000 - 0x91a45ff7 com.apple.Carbon 150 (152) <608A04AB-F35D-D2EB-6629-16B88FB32074> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x91a46000 - 0x91a93feb com.apple.DirectoryService.PasswordServerFramework 6.0 (6.0) <BF66BA5D-BBC8-78A5-DBE2-F9DE3DD1D775> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
0x91db1000 - 0x91e1bfe7 libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <411D87F4-B7E1-44EB-F201-F8B4F9227213> /usr/lib/libstdc++.6.dylib
0x91f09000 - 0x91f12ff7 com.apple.DiskArbitration 2.3 (2.3) <E9C40767-DA6A-6CCB-8B00-2D5706753000> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x92094000 - 0x9210efef com.apple.audio.CoreAudio 3.2.2 (3.2.2) <1F97B48A-327B-89CC-7C01-3865179716E0> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x92156000 - 0x92203fe7 libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <DF8E4CFA-3719-3415-0BF1-E8C5E561C3B1> /usr/lib/libobjc.A.dylib
0x92515000 - 0x92641fff com.apple.audio.toolbox.AudioToolbox 1.6.3 (1.6.3) <F0D7256E-0914-8E77-E37B-9720430422AB> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x92642000 - 0x926f2ff3 com.apple.ColorSync 4.6.3 (4.6.3) <68B6A1B9-86CF-0C5A-7D63-56ED4BB2EB5B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x926f3000 - 0x927acfe7 libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <16CEF8E8-8C9A-94CD-EF5D-05477844C005> /usr/lib/libsqlite3.dylib
0x927ad000 - 0x928aefe7 libxml2.2.dylib 10.3.0 (compatibility 10.0.0) <B4C5CD68-405D-0F1B-59CA-5193D463D0EF> /usr/lib/libxml2.2.dylib
0x92994000 - 0x929a0ff7 libkxld.dylib ??? (???) <13F26BB6-C2F7-9D74-933E-09AD8B509ECD> /usr/lib/system/libkxld.dylib
0x929a1000 - 0x929fcff7 com.apple.framework.IOKit 2.0 (???) <69E4FE93-376C-565E-650F-04FAD213AA24> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x92a05000 - 0x92a0aff7 com.apple.OpenDirectory 10.6 (10.6) <92582807-E8F3-3DD9-EB42-4195CFB754A1> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
0x92a73000 - 0x92b1cff7 com.apple.CFNetwork 454.9.4 (454.9.4) <2F8B5BA5-099F-6CDA-F500-4CA188BBCDBC> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x92b9c000 - 0x92bcdff7 libGLImage.dylib ??? (???) <AF110892-B10A-5B61-F898-21FB2BCE63BF> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x92ccd000 - 0x92dfbfe7 com.apple.CoreData 102.1 (251) <E6A457F0-A0A3-32CD-6C69-6286E7C0F063> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x92e09000 - 0x92ea6fe3 com.apple.LaunchServices 362.1 (362.1) <885D8567-9E40-0105-20BC-42C7FF657583> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x92ea7000 - 0x92eabff7 libGIF.dylib ??? (???) <03880BA1-7A86-0F2B-617A-C66B1D05DD70> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x93070000 - 0x930abfeb libFontRegistry.dylib ??? (???) <F50A60E1-3757-D007-A20D-A5504C17334C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x930ac000 - 0x930cbfe3 libexpat.1.dylib 7.2.0 (compatibility 7.0.0) <82E6F83F-9667-2E39-1D9D-4A49C642527D> /usr/lib/libexpat.1.dylib
0x930cc000 - 0x93271feb libSystem.B.dylib 125.0.1 (compatibility 1.0.0) <06A5336A-A6F6-4E62-F55F-4909A64631C2> /usr/lib/libSystem.B.dylib
0x93272000 - 0x93280ff7 com.apple.opengl 1.6.7 (1.6.7) <3C529790-DEE9-AC27-A879-806E4C23323C> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x93281000 - 0x9334bfef com.apple.CoreServices.OSServices 357 (357) <764872C3-AE30-7F54-494D-4BA3CE4F4DFB> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x9334c000 - 0x93368fe3 com.apple.openscripting 1.3.1 (???) <DA16DE48-59F4-C94B-EBE3-7FAF772211A2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x93369000 - 0x933ebffb SecurityFoundation 36840.0.0 (compatibility 1.0.0) <29C27E0E-B2B3-BF6B-B1F8-5783B8B01535> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x9340b000 - 0x93433ff7 libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <769EF4B2-C1AD-73D5-AAAD-1564DAEA77AF> /usr/lib/libxslt.1.dylib
0x93434000 - 0x93435ff7 com.apple.TrustEvaluationAgent 1.1 (1) <6C04C4C5-667E-2EBE-EB96-5B67BD4B2185> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x9369b000 - 0x936bcfe7 com.apple.opencl 12.1 (12.1) <1BCA4F60-E612-5C1B-EF50-A810D70CDF05> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x93873000 - 0x939f5fe7 libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <96A45E03-2B29-83EB-0FC6-2C932E398722> /usr/lib/libicucore.A.dylib
0x939f6000 - 0x93a46ff7 com.apple.framework.familycontrols 2.0.1 (2010) <50E74916-19A5-F2FC-AB57-76F2C8DDF0A7> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
0x93a47000 - 0x93a4aff7 libCoreVMClient.dylib ??? (???) <98CB96B1-85FE-25AF-AB19-ED061912FC3E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x93a4b000 - 0x93a4fff7 IOSurface ??? (???) <4B825ADA-8DBE-6BA2-1AB3-307D2C3AFCA8> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x93a50000 - 0x93cb2ff3 com.apple.security 6.1.1 (37594) <1AC07F75-7E27-9662-21DA-B05DFF047B26> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x93cc6000 - 0x93cccfff com.apple.CommonPanels 1.2.4 (91) <2438AF5D-067B-B9FD-1248-2C9987F360BA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x93ccd000 - 0x93cdbfe7 libz.1.dylib 1.2.3 (compatibility 1.0.0) <82B2C254-6F8D-7BEA-4C18-038E90CAE19B> /usr/lib/libz.1.dylib
0x93cdc000 - 0x93cdeff7 libRadiance.dylib ??? (???) <9358E1EF-F802-B76E-8E23-2D0695787CFB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x940bc000 - 0x940dcfe7 libresolv.9.dylib 40.0.0 (compatibility 1.0.0) <03019DD7-993D-AC88-6636-179F92F315C4> /usr/lib/libresolv.9.dylib
0x94124000 - 0x941bfff7 com.apple.ApplicationServices.ATS 4.2 (???) <3BEB7210-4C85-7309-B22D-695765526524> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x94203000 - 0x94247ff3 com.apple.coreui 2 (114) <29F8F1A4-1C96-6A0F-4CC2-9B85CF83209F> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x94248000 - 0x94568feb com.apple.CoreServices.CarbonCore 861.6 (861.6) <D3D5D9F1-01ED-DCAD-6AA9-4ABE60C7A112> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x94dab000 - 0x94dd1fff com.apple.DictionaryServices 1.1.1 (1.1.1) <02709230-9B37-C743-6E27-3FCFD18211F8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x94fe0000 - 0x95002fef com.apple.DirectoryService.Framework 3.6 (621.3) <05FFDBDB-F16B-8AC0-DB42-986965FCBD95> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x95003000 - 0x95006ff7 libCGXType.A.dylib 543.33.0 (compatibility 64.0.0) <69BE578C-A364-A150-35E3-53EE00F56F05> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
0x95032000 - 0x95043ff7 com.apple.LangAnalysis 1.6.6 (1.6.6) <7A3862F7-3730-8F6E-A5DE-8E2CCEA979EF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x95044000 - 0x95044ff7 com.apple.CoreServices 44 (44) <AC35D112-5FB9-9C8C-6189-5F5945072375> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x95045000 - 0x951beffb com.apple.CoreFoundation 6.6.1 (550.19) <1E97FB1E-9E42-B8EB-E463-5C75315FDA31> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x951bf000 - 0x951d4fff com.apple.ImageCapture 6.0 (6.0) <3F31833A-38A9-444E-02B7-17619CA6F2A0> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x95295000 - 0x956abff7 libBLAS.dylib 219.0.0 (compatibility 1.0.0) <C4FB303A-DB4D-F9E8-181C-129585E59603> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x956ac000 - 0x956acff7 com.apple.Cocoa 6.6 (???) <EA27B428-5904-B00B-397A-185588698BCC> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x959fd000 - 0x95aa5ffb com.apple.QD 3.35 (???) <B80B64BC-958B-DA9E-50F9-D7E8333CC5A2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x95aa6000 - 0x95b5cfff libFontParser.dylib ??? (???) <5935E105-1E45-886C-6420-C1CCA886C375> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x95b9e000 - 0x95be4ff7 libauto.dylib ??? (???) <85670A64-3B67-8162-D441-D8E0BE15CA94> /usr/lib/libauto.dylib
0x95c18000 - 0x95c23ff7 libCSync.A.dylib 543.33.0 (compatibility 64.0.0) <F914F427-98EA-98BC-923D-47274A90D441> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x95c2c000 - 0x9650bff7 com.apple.AppKit 6.6.5 (1038.29) <E76A05A6-27C6-DA02-0961-5C8EEDC5F0A7> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x96516000 - 0x96519fe7 libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <1622A54F-1A98-2CBE-B6A4-2122981A500E> /usr/lib/system/libmathCommon.A.dylib
0x9651a000 - 0x9653eff7 libJPEG.dylib ??? (???) <EDA86712-F49C-760C-BE55-9B899A4A5D1B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x9653f000 - 0x96863fef com.apple.HIToolbox 1.6.2 (???) <F5F99E78-5377-DD54-6138-9FC84467F938> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x977b6000 - 0x97a26ffb com.apple.Foundation 6.6.2 (751.21) <DA7A173A-4435-ECD6-F4AF-977D722FD2F7> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x97a2e000 - 0x97d95ff7 com.apple.QuartzCore 1.6.1 (227.18) <8A65F233-4C77-BA7C-5DDA-2423F5C1B7A1> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x97d96000 - 0x97ea2ff7 libGLProgrammability.dylib ??? (???) <CA0A975B-2BEE-44E7-CFA6-8105CFE6FE00> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x97ea3000 - 0x97eadfe7 com.apple.audio.SoundManager 3.9.3 (3.9.3) <5F494955-7290-2D91-DA94-44B590191771> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x9870e000 - 0x9870eff7 com.apple.Accelerate 1.6 (Accelerate 1.6) <BC501C9F-7C20-961A-B135-0A457667D03C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x9870f000 - 0x987ecff7 com.apple.vImage 4.0 (4.0) <64597E4B-F144-DBB3-F428-0EC3D9A1219E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x987ed000 - 0x9889bff3 com.apple.ink.framework 1.3.3 (107) <57B54F6F-CE35-D546-C7EC-DBC5FDC79938> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x989d1000 - 0x98ac3ff7 libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <7482933B-4AF6-ED55-AD72-4FBD1E134958> /usr/lib/libcrypto.0.9.8.dylib
0x98ac4000 - 0x98ac6ff7 com.apple.securityhi 4.0 (36638) <962C66FB-5BE9-634E-0810-036CB340C059> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x98ac7000 - 0x98ac7ff7 liblangid.dylib ??? (???) <B99607FC-5646-32C8-2C16-AFB5EA9097C2> /usr/lib/liblangid.dylib
0x98ac8000 - 0x98b19ff7 com.apple.HIServices 1.8.0 (???) <10C85B88-C6AF-91DB-2546-34661BA35AC5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x98c0f000 - 0x98c1aff7 libGL.dylib ??? (???) <EAD85409-9036-831B-C378-E50780305DA6> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x98ca0000 - 0x98ce3ff7 com.apple.NavigationServices 3.5.4 (182) <753B8906-06C0-3AE0-3D6A-8FF5AC18ED12> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x98d1e000 - 0x98d1fff7 com.apple.audio.units.AudioUnit 1.6.3 (1.6.3) <959DFFAE-A06B-7FF6-B713-B2076893EBBD> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x98f51000 - 0x98fe3fe3 com.apple.print.framework.PrintCore 6.2 (312.5) <7729B4D7-D661-D669-FA7E-510F93F685A6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x98fe4000 - 0x98fe4ff7 com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) <1DEC639C-173D-F808-DE0D-4070CC6F5BC7> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x98fe5000 - 0x99046fe7 com.apple.CoreText 3.1.0 (???) <1372DABE-F183-DD03-03C2-64B2464A4FD5> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x99495000 - 0x994a2ff7 com.apple.NetFS 3.2.1 (3.2.1) <5E61A00B-FA16-9D99-A064-47BDC5BC9A2B> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x994a3000 - 0x994e7fe7 com.apple.Metadata 10.6.3 (507.8) <53BB360A-1813-170D-827F-C1863EF15537> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x994ea000 - 0x994f1ff3 com.apple.print.framework.Print 6.1 (237.1) <97AB70B6-C653-212F-CFD3-E3816D0F5C22> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x994f2000 - 0x99533ff7 libRIP.A.dylib 543.33.0 (compatibility 64.0.0) <C6E50C7E-EBEE-32AF-FF07-8E325E21A838> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x99534000 - 0x99569ff7 libcups.2.dylib 2.8.0 (compatibility 2.0.0) <458E819A-4E3F-333E-28CE-671281B318D3> /usr/lib/libcups.2.dylib
0x9956a000 - 0x9959bff3 libTrueTypeScaler.dylib ??? (???) <F6A32C01-CD82-54F6-218E-0406D40D1D9A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x9959c000 - 0x995baff7 com.apple.CoreVideo 1.6.1 (45.4) <E0DF044D-BF31-42CE-B690-FD1FCE07E64A> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x995be000 - 0x99601ff7 libGLU.dylib ??? (???) <CE02968E-930D-E63B-7B21-B87205F8B19A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x99650000 - 0x9968dff7 com.apple.SystemConfiguration 1.10.2 (1.10.2) <830FED9E-3E24-004C-35D5-2C1273F79734> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0xffff0000 - 0xffff1fff libSystem.B.dylib ??? (???) <06A5336A-A6F6-4E62-F55F-4909A64631C2> /usr/lib/libSystem.B.dylib
Model: Macmini2,1, BootROM MM21.009A.B00, 2 processors, Intel Core 2 Duo, 1.83 GHz, 1 GB, SMC 1.19f0
Graphics: Intel GMA 950, GMA 950, Built-In, spdisplays_integrated_vram
Memory Module: global_name
AirPort: spairport_wireless_card_type_airport_extreme (0x168C, 0x86), Atheros 5424: 2.0.19.10
Bluetooth: Version 2.3.1f4, 2 service, 19 devices, 1 incoming serial ports
Network Service: Ethernet, Ethernet, en0
Serial ATA Device: Hitachi HTS541680J9SA00, 74,53 GB
Parallel ATA Device: MATSHITACD-RW CW-8124
USB Device: Bluetooth USB Host Controller, 0x05ac (Apple Inc.), 0x8205, 0x7d100000
USB Device: IR Receiver, 0x05ac (Apple Inc.), 0x8240, 0x7d200000
FireWire Device: Ensemble, Apogee Electronics, Up to 400 Mb/sec
