A SPL meter is required, Without one you can't accomplish REW's SPL calibration routine, where the program "learns" that 75 dB is 75 dB, and not some other arbitrary figure. If this is not done, the vertical axis dB designations on the graphs REW generates are meaningless.
As a side benefit, the Radio Shack SPL meter is also suitable for accurate low frequency measurement. So if low frequency subwoofer measurements are all you're interested in, then the Radio Shack meter is all you need.
However, if you desire accurate full range measurements, a calibrated mic is required in addition to the SPL meter. The calibrated mic will also require a mic pre amp and, depending on the mic you use, phantom power as well. We typicallly recommend the Behringer ECM8000 mic or its equivalent that is available from other manufacturers. We also provide a generic calibration file for the ECM8000. However, the best accuracy is assured by purchasing a mic with a custom calibration file (i.e. specific calibration to the specific mic). We have a recommended vendor Cross Spectrum, that provides custom calibrated mics.
However, any mic can be used, as long as there is a calibration file available. A calibration file can be created if there is a manufacturer's frequency response graph available as a reference.
ALTERNATELY, the Galaxy CM-140 SPL meter is accurate enough to do full range measurements (unlike the Radio Shack meter). So it could do everything you want in a single package.
