1 - 13 of 13 Posts
REW 3.9 works perfectly, but, having installed version 4 it tells me it can't find output device.
I am using a RME sound card.
Any suggestions would be appriciated.
Ken
Hi Ken,
Please generate a soundcard debug file using the option on the soundcard settings tab, and also say what input and output were shown when all was working OK in REW V3.29. What happens if you set REW to use the default input and output devices (and have those set up as being the RME card in the Windows Sounds and Audio devices properties)?
Discussion Starter #4
Thanks Sonnie, RME is a quality sound card. The model is RME Hammerfall DSP 9632.
Thanks for the reply John, I will get those figures together later.
The RME card cannot be set as the default sound card in windows and a different device has to be set as default, according to the manual; but only if you want to use windows sounds.
When opening the Control panel/Sound and Audio Devices, it shows No Sound Device on the the opening panel; This is normal for the RME card apparently; this therefore means that volume cannot be controlled by windows; even though I have the RME analogue siganals set as the default in the drop down panels within the Audio Tab.
With REW v3.29 this was not a problem, as far as being able to use the card.
In v3.29 Input and Output could be set to the RME analogue in/outs or Primary sound driver, without issue; I just have to control volume with the Processor or the RME mixer.
If I set the on-board sound device, as default, it is instantly recognised, but to use this sound device would entail a lot of cable adapters being made as I use XLR connectors throughout, and I'd rather avoid that if possible.
In v4 at start up it hunts for the sound card and ends up with an output device error; manually selecting the card, no matter which selection, ends up with a very long wait for the program to find no output device. I suspect that because the card is not contollable by windows it is not recognised by REW either.
If this cannot be resolved, at least I can continue to use v3.29, but v4 looks really nice.
Ken
Thanks Ken, will await the debug file. Can you also please check the roomeqwizardxx.log.txt files in your home directory and see if REW has logged any additional info in there.
Discussion Starter #7
John, here is the soundcard debug file. It was too long so I removed the details of the ADAT mixer inputs, which are not in use; it's still very long.
SoundCard Debug Data generated by Room EQ Wizard V4.00
Dated: 25-Jan-2007 15:00:48
Input Device: Primary Sound Capture Driver
Input: No input selected
Input Volume: no control
Output Device: Primary Sound Driver
Output: SPEAKER
Output Volume: 0.500
Output Mute: Off
Wave Volume: 0.000
Wave Mute: Off
0: Primary Sound Driver, Unknown Vendor, Unknown Version, Direct Audio Device: DirectSound Playback
Line interface SourceDataLine supporting 8 audio formats, and buffers of at least 32 bytes (max. -1 simultaneously):
0: PCM_UNSIGNED unknown sample rate, 8 bit, mono, 1 bytes/frame, (1 channels, frameSize=1, little endian)
1: PCM_SIGNED unknown sample rate, 8 bit, mono, 1 bytes/frame, (1 channels, frameSize=1, little endian)
2: PCM_SIGNED unknown sample rate, 16 bit, mono, 2 bytes/frame, little-endian (1 channels, frameSize=2, little endian)
3: PCM_SIGNED unknown sample rate, 16 bit, mono, 2 bytes/frame, big-endian (1 channels, frameSize=2, big endian)
4: PCM_UNSIGNED unknown sample rate, 8 bit, stereo, 2 bytes/frame, (2 channels, frameSize=2, little endian)
5: PCM_SIGNED unknown sample rate, 8 bit, stereo, 2 bytes/frame, (2 channels, frameSize=2, little endian)
6: PCM_SIGNED unknown sample rate, 16 bit, stereo, 4 bytes/frame, little-endian (2 channels, frameSize=4, little endian)
7: PCM_SIGNED unknown sample rate, 16 bit, stereo, 4 bytes/frame, big-endian (2 channels, frameSize=4, big endian)
Controls[0]: FloatControl: Master Gain with current value: 0.0 dB (range: -80.0 - 6.0206)
Controls[1]: BooleanControl: Mute Control with current value: False
Controls[2]: FloatControl: Balance with current value: 0.0 (range: -1.0 - 1.0)
Controls[3]: FloatControl: Pan with current value: 0.0 (range: -1.0 - 1.0)
Line interface Clip supporting 8 audio formats, and buffers of at least 32 bytes (max. -1 simultaneously):
[no controls]
1: HDSP Analog Out (1+2)(1) (emulated), Unknown Vendor, Unknown Version, Direct Audio Device: DirectSound Playback
LineUnavailableException when trying to open this line
[no controls]
6: HDSP SPDIF Out (1) (emulated), Unknown Vendor, Unknown Version, Direct Audio Device: DirectSound Playback
[no controls]
7: SoundMAX Digital Audio, Unknown Vendor, Unknown Version, Direct Audio Device: DirectSound Playback
[no controls]
8: Primary Sound Capture Driver, Unknown Vendor, Unknown Version, Direct Audio Device: DirectSound Capture
Line interface TargetDataLine supporting 8 audio formats, and buffers of at least 32 bytes (max. -1 simultaneously):
[no controls]
9: HDSP Analog In (1+2)(1) (emulated), Unknown Vendor, Unknown Version, Direct Audio Device: DirectSound Capture
[no controls]
14: HDSP SPDIF In (1) (emulated), Unknown Vendor, Unknown Version, Direct Audio Device: DirectSound Capture
[no controls]
15: SoundMAX Digital Audio, Unknown Vendor, Unknown Version, Direct Audio Device: DirectSound Capture
[no controls]
16: Java Sound Audio Engine, Sun Microsystems, 1.0, Software mixer and synthesizer
Line interface SourceDataLine supporting 8 audio formats (max. 32 simultaneously):
0: PCM_SIGNED unknown sample rate, 8 bit, mono, 1 bytes/frame, (1 channels, frameSize=1, little endian)
1: PCM_UNSIGNED unknown sample rate, 8 bit, mono, 1 bytes/frame, (1 channels, frameSize=1, little endian)
2: PCM_SIGNED unknown sample rate, 8 bit, stereo, 2 bytes/frame, (2 channels, frameSize=2, little endian)
3: PCM_UNSIGNED unknown sample rate, 8 bit, stereo, 2 bytes/frame, (2 channels, frameSize=2, little endian)
4: PCM_SIGNED unknown sample rate, 16 bit, mono, 2 bytes/frame, big-endian (1 channels, frameSize=2, big endian)
5: PCM_SIGNED unknown sample rate, 16 bit, mono, 2 bytes/frame, little-endian (1 channels, frameSize=2, little endian)
6: PCM_SIGNED unknown sample rate, 16 bit, stereo, 4 bytes/frame, big-endian (2 channels, frameSize=4, big endian)
7: PCM_SIGNED unknown sample rate, 16 bit, stereo, 4 bytes/frame, little-endian (2 channels, frameSize=4, little endian)
Controls[0]: FloatControl: Master Gain with current value: 0.0 dB (range: -80.0 - 13.9794)
Controls[2]: FloatControl: Pan with current value: 0.0 (range: -1.0 - 1.0)
Controls[3]: FloatControl: Sample Rate with current value: 44100.0 FPS (range: 0.0 - 48000.0)
Line interface Clip supporting 8 audio formats, and buffers of 0 to 4194304 bytes (max. 32 simultaneously):
17: Port SoundMAX Digital Audio, Unknown Vendor, 5.10, Port Mixer
Port COMPACT_DISC source port
Controls[0]: CompoundControl: CD Player Control containing Select, Volume, and Balance Controls.
MemberControls[0]: BooleanControl: Select Control with current value: false
MemberControls[1]: FloatControl: Volume with current value: 0.23041123 (range: 0.0 - 1.0)
MemberControls[2]: FloatControl: Balance with current value: -3.809171E-9 (range: -1.0 - 1.0)
Port MICROPHONE source port
Controls[0]: CompoundControl: Microphone Control containing Select, MIC Boost, Mic2 Select, and Volume Controls.
MemberControls[1]: BooleanControl: MIC Boost Control with current value: false
MemberControls[2]: BooleanControl: Mic2 Select Control with current value: false
MemberControls[3]: FloatControl: Volume with current value: 0.3254597 (range: 0.0 - 1.0)
Port Aux source port
Controls[0]: CompoundControl: Aux Control containing Select, Volume, and Balance Controls.
Port LINE_IN source port
Controls[0]: CompoundControl: Line In Control containing Select, Volume, and Balance Controls.
MemberControls[0]: BooleanControl: Select Control with current value: true
Port Phone source port
Controls[0]: CompoundControl: Phone Control containing Select, and Volume Controls.
MemberControls[1]: FloatControl: Volume with current value: 0.09715419 (range: 0.0 - 1.0)
Port Mono Out source port
Controls[0]: CompoundControl: Mono Out Control containing Select, and Volume Controls.
Port Wave Out Mix source port
Controls[0]: CompoundControl: Wave Out Mix Control containing Select, Volume, and Balance Controls.
MemberControls[1]: FloatControl: Volume with current value: 0.08174258 (range: 0.0 - 1.0)
MemberControls[2]: FloatControl: Balance with current value: 3.726125E-8 (range: -1.0 - 1.0)
Port SPEAKER target port
Controls[0]: FloatControl: Volume with current value: 0.5000076 (range: 0.0 - 1.0)
Controls[1]: FloatControl: Balance with current value: 2.3283064E-10 (range: -1.0 - 1.0)
Controls[2]: BooleanControl: AC3 SPDIF Control with current value: true
Controls[3]: BooleanControl: PCM SPDIF Control with current value: true
Controls[4]: BooleanControl: Mute Control with current value: false
Controls[5]: CompoundControl: Wave Control containing Volume, Balance, and Mute Controls.
MemberControls[0]: FloatControl: Volume with current value: 0.0 (range: 0.0 - 1.0)
MemberControls[1]: FloatControl: Balance with current value: 0.0 (range: -1.0 - 1.0)
MemberControls[2]: BooleanControl: Mute Control with current value: false
Controls[6]: CompoundControl: SW Synth Control containing Volume, Balance, and Mute Controls.
MemberControls[0]: FloatControl: Volume with current value: 1.0 (range: 0.0 - 1.0)
MemberControls[2]: BooleanControl: Mute Control with current value: true
Controls[7]: CompoundControl: CD Player Control containing Volume, Balance, and Mute Controls.
MemberControls[0]: FloatControl: Volume with current value: 0.25117877 (range: 0.0 - 1.0)
MemberControls[1]: FloatControl: Balance with current value: -4.7041716E-8 (range: -1.0 - 1.0)
Controls[8]: CompoundControl: Microphone Control containing Mic2 Select, MIC Boost, Volume, and Mute Controls.
MemberControls[0]: BooleanControl: Mic2 Select Control with current value: false
MemberControls[2]: FloatControl: Volume with current value: 0.3254597 (range: 0.0 - 1.0)
MemberControls[3]: BooleanControl: Mute Control with current value: true
Controls[9]: CompoundControl: Aux Control containing Volume, Balance, and Mute Controls.
MemberControls[0]: FloatControl: Volume with current value: 0.23041123 (range: 0.0 - 1.0)
MemberControls[1]: FloatControl: Balance with current value: -3.809171E-9 (range: -1.0 - 1.0)
Controls[10]: CompoundControl: Line In Control containing Volume, Balance, and Mute Controls.
Controls[11]: CompoundControl: Phone Control containing Volume, and Mute Controls.
MemberControls[1]: BooleanControl: Mute Control with current value: true
Controls[12]: CompoundControl: Mono Out Control containing Volume, and Mute Controls.
Ken
Discussion Starter #8
I decided to make the cables and use the computers onboard sound card. All is working fine.
This is an excellent program John, thank you for sharing it.
Ken
I have a RME 9632 card with the latest firmware and drivers. Since it is a commonly used sound card among musicians/audiophiles it would be nice to be able to use it with REW. This is my debug file:
SoundCard Debug Data generated by Room EQ Wizard V4,00
Dated: 2007-mar-06 17:41:09
Input Device: HDSP Analog In (1+2)(1) (emulerad)
Output Device: HDSP Analog Out (1+2)(1) (emulerad)
Output: No output selected
Output Volume: No control
Output Mute: Off
Wave Volume: No control
Wave Mute: Off
0: Primär ljuddrivrutin, Unknown Vendor, Unknown Version, Direct Audio Device: DirectSound Playback
[no controls]
1: C-Media Wave Device, Unknown Vendor, Unknown Version, Direct Audio Device: DirectSound Playback
[no controls]
DATA DELETED
7: HDSP Analog Out (1+2)(1) (emulerad), Unknown Vendor, Unknown Version, Direct Audio Device: DirectSound Playback
[no controls]
8: Primär drivrutin för ljudinfångst, Unknown Vendor, Unknown Version, Direct Audio Device: DirectSound Capture
[no controls]
9: USB Camera, Unknown Vendor, Unknown Version, Direct Audio Device: DirectSound Capture
[no controls]
10: HDSP ADAT In (1+2)(1) (emulerad), Unknown Vendor, Unknown Version, Direct Audio Device: DirectSound Capture
[no controls]
11: HDSP ADAT In (3+4)(1) (emulerad), Unknown Vendor, Unknown Version, Direct Audio Device: DirectSound Capture
[no controls]
12: HDSP ADAT In (5+6)(1) (emulerad), Unknown Vendor, Unknown Version, Direct Audio Device: DirectSound Capture
[no controls]
13: HDSP ADAT In (7+8)(1) (emulerad), Unknown Vendor, Unknown Version, Direct Audio Device: DirectSound Capture
[no controls]
14: HDSP SPDIF In (1) (emulerad), Unknown Vendor, Unknown Version, Direct Audio Device: DirectSound Capture
[no controls]
15: HDSP Analog In (1+2)(1) (emulerad), Unknown Vendor, Unknown Version, Direct Audio Device: DirectSound Capture
[no controls]
16: C-Media Wave Device, Unknown Vendor, Unknown Version, Direct Audio Device: DirectSound Capture
[no controls]
17: Java Sound Audio Engine, Sun Microsystems, 1.0, Software mixer and synthesizer
18: Port C-Media Wave Device, Unknown Vendor, 5.10, Port Mixer
Port SPDIF In source port
Controls[0]: CompoundControl: SPDIF In Control containing Select, Mute, and Validity Check Controls.
MemberControls[1]: BooleanControl: Mute Control with current value: false
MemberControls[2]: BooleanControl: Validity Check Control with current value: false
Port Stereo Mix source port
Controls[0]: CompoundControl: Stereo Mix Control containing Select, Volume, and Balance Controls.
MemberControls[1]: FloatControl: Volume with current value: 0.07498284 (range: 0.0 - 1.0)
MemberControls[2]: FloatControl: Balance with current value: -4.323884E-8 (range: -1.0 - 1.0)
Controls[0]: CompoundControl: Mikrofon Control containing Select, Mikrofonförstärkning, Alternativ mikrofon, and Volume Controls.
MemberControls[1]: BooleanControl: Mikrofonförstärkning Control with current value: false
MemberControls[2]: BooleanControl: Alternativ mikrofon Control with current value: false
MemberControls[3]: FloatControl: Volume with current value: 0.07498284 (range: 0.0 - 1.0)
Controls[0]: CompoundControl: CD-spelaren Control containing Select, Volume, and Balance Controls.
Port Aux/Phone source port
Controls[0]: CompoundControl: Aux/Phone Control containing Select, Volume, and Balance Controls.
Controls[0]: CompoundControl: Linjeingång Control containing Select, Volume, and Balance Controls.
Port Wave source port
Controls[0]: CompoundControl: Wave Control containing Select, Volume, and Balance Controls.
Controls[0]: FloatControl: Volume with current value: 0.49399558 (range: 0.0 - 1.0)
Controls[1]: FloatControl: Balance with current value: -4.4803823E-9 (range: -1.0 - 1.0)
Controls[3]: CompoundControl: Wave Control containing Volume, Balance, and Mute Controls.
Controls[4]: CompoundControl: Synthesizer Control containing Volume, Balance, and Mute Controls.
Controls[5]: CompoundControl: Mono In Control containing Volume, and Mute Controls.
Controls[6]: CompoundControl: Mikrofon Control containing Alternativ mikrofon, Mikrofonförstärkning, Volume, and Mute Controls.
MemberControls[0]: BooleanControl: Alternativ mikrofon Control with current value: false
MemberControls[2]: FloatControl: Volume with current value: 0.25117877 (range: 0.0 - 1.0)
Controls[7]: CompoundControl: CD-spelaren Control containing Volume, Balance, and Mute Controls.
Controls[8]: CompoundControl: Aux/Phone Control containing Volume, Balance, and Mute Controls.
Controls[9]: CompoundControl: Linjeingång Control containing Volume, Balance, and Mute Controls.
Cheers,
Mats
Does the RME have WDM drivers? I suspect it may be ASIO only, which JavaSound does not support. Adding ASIO support is on the dev list but a long way off.
Discussion Starter #11
John, It looks like RME released new WDM drivers last week, so I will try them when I get home next week.
Ken
1 - 13 of 13 Posts
