1 - 3 of 3 Posts
Hi. REW4.11 runs fine in my Ubuntu 10.10 with JRE6, but when I run version 5beta I cannot see the main display with all the measurement options. I can only see the Top menu (Measure, Open, ..., RTA, Eq, Preferences) and some icons are even grayed out, such as IR Windows and Overlays, although I presume that is not an issue. Generator, SPL, RTA and others work fine.
I really want this to work, since there are features I really appreciate in v5b. Now that I think of it, in v4.11 some functions appear grayed out as well, such as RT60, but at least the main graph and tabs are available.
Do you think this is a Java problem? Has anybody had a similar problem? Should I look into adding additional libraries, etc. to jre6?
Thanks!
After you enlarge the main window look for the Preferences button (way) to the right of the EQ button. The window you are looking for *was* the main display as I recall but that is not the case in v5.
1 - 3 of 3 Posts
