1 - 10 of 10 Posts
Is there any problem using RG-6QS as sub cable? I cannot imagine one. I just ran one and have less hum pickup than a Monster sub cable. The coax is run via a different route, so that may be the difference.
The only problem I have is terminating into RCA plugs. I put Snap-N-Seal F connectors on the coax, then used F to RCA converters at each end. The strain of the cable has already pulled one of the F to RCA converters apart. I see that MCM has Snap-N-Seal RCA plugs, so I think I will order some of them.
I must have gotten a bad batch. I had another one separate last night with only slight movement of the cable. Oh well, I have Snap-N-Seal RCA plugs on order that will be here later this week.
The adapters I am using don't seem to have the F connector screwed onto the RCA. They appear to be press fitted - and that seems to be the problem. They are coming apart where the F joins the RCA, resulting in a broken center conductor and separation of the shell.
1 - 10 of 10 Posts
