1 - 1 of 1 Posts
could i use the crown 1502 to safely drive a single duel 4ohm sub with an rms of 500watts [250 per coil] wired to 2ohms (one on the left an one on the right channel)
an feed each 775watts my woofers is the Audiopipe 15" TS-CVR 4-ohm DVC
without burning them out
i think it would be 137.5watts over rms per coil total would be 275watts
according to the crown amp calculator 767watts would give me
my Desired level (100db for dynamic scenes ) at listener distance 7.5feet from my subs
with a Loudspeaker sensitivity rating (1W/1M) 91db
with 13db of Amplifier headroom
the Required Amplifier Power 767watt so 775 should be enough
1 - 1 of 1 Posts
