21 - 26 of 26 Posts
The L will be the least effective in terms of deep bass - but it has the most surface area.
The chunk will reach the deepest assuming the same face dimensions as the straddling panels.
The straddling panels will do 90% of what the chunk will do down to say the 70's then the chunk pulls away.
From a DIY perspective assuming the same material, the chunk will cost 50% more than the straddling panel. The L will cost double what the straddling panel will.
Bryan
And that's why he does what he does for a living folks. Great post Bryan.
Another one for Brian,
I have 12' ceilings and would like to minimize the "look" of a corner bass trap.
How much of a difference is going from a one 4' section to two or three?
In bass treatment, more is always better. :bigsmile:
Bob
Doing multiples is definitely beneficial. Not only are you getting additional surface area, but you're distributing it more evenly in the vertical dimension.
Bryan
Is it possible to see curves, before an after? It would be self-expressive.
21 - 26 of 26 Posts
