1 - 7 of 7 Posts
Does anyone know where I can find the calibration file for the Behringer ECM8000 measurement microphone so I can get an accurate as possible reading of my room in room eq wizard?
..actualy I think I've changed my mind on which microphone to get after reading an article that your link took me to. The umik-1 seems like a smart choice. Would you agree?
Yes, the umik1 is perfect. Ive got one now and the readings are much more accurate particularly on the high end.
I have the Umic & it is much more precise.
I have had good luck with the Earthworks TC30. It comes with a calibration graph which is flat (within .1db) to 30 kilohertz.
You must have bar-code on the mic. Then, you can ask Behringer to get the file with some price.
I use beringer, too. I created compensation file from the catalog. But it may not be accurate.
I also use two miniDSP's UMIK-1 USB mic. Which is inexpensive and all mics have compensation file downloadable depanding upon the serial number. And on top, tripod is attached. I love this.
Yuichi
1 - 7 of 7 Posts
