Hi Guys:
I am trying to connect my Sunfire TG2 via its RS-232 port to my MacBook. I found an inexpensive cable and some of the codes in the Sunfire manual but don't know what to do with them!
Where can I find a program to input the codes and actually use the Mac as a wired remote?
Eventually, I would like to use an iTouch or iPhone as a remote with iTunes (easy) and to control the Sunfire also (not easy?); any ideas on making the link between the iTouch and Sunfire?
Thanks!
Thanks!
