1 - 7 of 7 Posts
Senior Shackster , Platinum Supporter
Have a question......
Can I use the rta on the REW without the sound car on my laptop???
Thanks!!!!!!!!
:dontknow::dontknow:
Generally laptop soundcards aren't suitable, since they don't have a line-in, so an external USB soundcard is recommended.
Using the RTA is no different (with respect to the equipment required) than taking regular response measurements.
What about the mic in??
Nope - no good. Your Radio Shack SPL meter is a line-out device and requires a line-in port. The mic-in ports are completely unsuitable.... You require an external soundcard - they're quite inexpensive....
Discussion Starter #6
What if the laptop has a line-in????
1 - 7 of 7 Posts
