Dear experts,
I’ve a question about amplifier and speaker. I would amp a 50W RMS 4 Ohm speaker with a 350W amp (Crown 1000)
I understand that amplifiers have to be bigger than speakers, but my concern here is how to get the maximum output from this set up without destroying everything. I have all the hardware and software to measure SPL (MiniDSP calibrated mic, REW) and I know how to use
The sensitivity is 87 dB at 1W/1m
Is there any way to do some sort of “scientific” testing to get the maximum output from the speaker so I can set a max gain on the amp to avoid bad surprise? I read that “pump the volume up until they distort” could fit my scope, but I would like to be more precise…
I was thinking to run pink noise by REW until I read 105dB SPL @ 1m: does it make sense?
Thanks in advance for your help!
Cheers
Cheers
