1 - 10 of 10 Posts
I tried to use 3m 90 spray tack on r13 insulation and the inside of a sonotube with the plastic peeled off and it would not stick well because the insulation sucked up all then glue.
I threw away the insulation becaus eI figured it was not needed then got advice that I REALLY should use something. Now I have the ports and some bracing in place so I can only parcially cover the sides if needed.
I need to know:
1. in a 6' x 25" sono do I need stuffing for standing waves and decay time?
2. Would a rubber coating do the same job of reducing resonance?
3. Is there any other adhesive or stuffing I can get locally at lowes or home depot or michaels (craft chain)?
Yes I did, sorry if I didn't make it clear ha...
The insulation just turned kind of crispy but not sticky and absorbed it all. I would even prefer to get something else now that I threw all my pealed and cut insulation away and would prefer not to go through that process again
I REALLY cant reach the top of the tube, just not an option.... would doing the sides be worth the effort?
The rubber coating is something I read on a DIY page, it made sense, he put a rubber coating on and it reduced the echoeing of the tube like when you hit it, it did not resonate
Just a thought, What about carpet underlay? It would be easy to glue and defiantly has some sound absorbing properties.
I used Black carpet underlay on the top half of my theater room walls and used contact cement however for your case spray glue should work fine.
Sure, that should hold it in place.
1 - 10 of 10 Posts
