1 - 5 of 5 Posts
I'd say there is a fair-to-good chance you can get them working together. I have run 2 USB interfaces on the same PC before, Win 7-64. They will have to all be running the same kind of drivers, i.e. all asio - the DAW will generally only work with one driver system at a time - but that should not be an issue with those interfaces.
Here is how I would approach it:
  • Install 1 at a time, get that combination working before installing the next.
  • ASIO4ALL should be a help
  • carefully work from outside to inside: driver settings, DAW sample rate, then asio settings from your DAW's asio panel, then the DAW I/O settings
  • sometimes you have to go back and forth several times between the asio panel and the port selection for the DAW; example:
    • -DAW - delete existing ports
    • -quit the DAW & re-open
    • -asio panel: select device and ports
    • -close, quit the DAW and re-open
    • -DAW - select ports, close and re-open
    • -asio panel - reselect something that didn't lock in before, close & re-open DAW
    • -reselect the DAW i/o ports, close & re-open
    • -etc
    • You will think you have done it just right but the I/O you want doesn't show up; so you do it over and close and re-open and do it again in the asio panel and after about 4 more times of doing the same thing again and again and quitting and re-opening.... suddenly it is all there and works just fine (and once there it will stay there). Frustrating, but that is what it takes sometimes.
  • Your overhead with multiple devices will be higher, but it sounds like you have a hot machine, too. Don't expect the lowest latency. But for tracking live, you just want clean tracks, low latency is not really an issue unless you want to overdub or add tracks later on.
  • you probably know this, but... when installing the driver for each interface, do the installation without the device plugged into the usb port, then plug in the device last
Sounds like fun. Best of luck, and let us know how it turns out.
Did test it live yet. Had some glitches along the stress-testingroad, but it was all Microsoft's fault for releasing too much useless stuff in their OS.... completely stripped down the OS, it's running like a dream again :)
Recordings are on it's way (5th of october first live-gig recordings for a good friend of mine, fingers crossed!)
I'll keep you guys posted!
Hey, that is great info. I assume you mean the "turn windows features on or off" panel.
If you have the time, could you give us a list of what you left active, or maybe a screenshot of that panel with all the subcategories expanded out? I have struggled with that over the years, wanting to turn off unneeded features for a music production focus, but not wanting to totally cripple the machine. Any main capabilities you had to sacrifice? Networking, etc?
Anyone else have experience in this area they can share?
One key for getting best performance for glitch-free tracking seems to be:
  • All networking turned off - control panel > device manager > network adapter > disable.
  • All antivirus turned off.
Turn on antivirus before turning the network adapter back on. Disabling/enabling the network adapter is quick, clean, effective. Working through the Network Connection Center is not nearly as clear cut.
1 - 5 of 5 Posts
