Specifications
Driver
DS1510 15" high excursion with custom sensing coil
Driver materials
Black anodized aluminum with rubber surround
Cast aluminum basket
Copper flux modulation shorting rings
Amplifier
600 RMS class H patented servo controlled
Dimensions
19"(W) x 19 " (H )x 20 "(D) - (21-1/2" D with grille)
Shipping Weight
108 lbs
Frequency Response
14 - 200 Hz (-2 dB @ 14 Hz) with LFE inputs
14 - 90 Hz (-2 dB @ 14 Hz) with LINE IN inputs
Crossover slope
Selectable 12 or 24 dB / octave (PEQ and XLR versions)
Crossover range (Low pass)
25 - 100 Hz
Rumble Filter (High pass )
20 Hz 18 dB / octave
Phase response
90 degrees phase shift at 20 Hz
Phase adjustment
0 - 180 degrees continuously variable
Bass damping factor settings
high (Q=0.5), med (Q=0.7), and low (Q=1.1)
Finishes
Available in honey oak vinyl or black oak vinyl
Warranty
5 years warranty on driver and 2 years on electronics
30 day satisfaction guarantee
Driver materials
Amplifier
Dimensions
Shipping Weight
108 lbs
Frequency Response
Crossover slope
25 - 100 Hz
Phase response
Phase adjustment
Finishes
Warranty
Manufacturers Published Measurements
Frequency Response
Max Output Before Compression
Spectral Decay
Group Delay
Waterfall
Spectrogram
Harmonic Distortion
32 Hz
40 Hz
50 Hz
63 Hz
70 Hz
80 Hz
