1 - 17 of 17 Posts
Ok so my original plan was to build two sealed Rythimk 1505’s($1,200) or 1510hp’s(1,460).
The significant other seems to think that is to much. :crying: So now I’m just thinking maybe one 1510hp (730)
My room is about 3,900 cu.ft. Barrel vaulted. Music/Movies is probably 60/40 and I don’t listen at earth shattering db levels. My strong points are carpentry so building the boxes is a must, but I’m not well versed in subwoofer EQ or REW.
I originally wanted to go with Rythmik for the sound quality and ease of all included diy kits from Bryan.
Now my big question is would I be better off buying two Dayton RSS390HO’s and something like a Behringer NU3000DSP iNUKE for roughly the same price as one Rythmik 1510?
Any input or ideas to help me make a decision would be great.
I also wouldn’t know what size boxes to build for the Dayton’s if I went that direction. With the Rythmiks I had figured about 3.5 cu.ft.
Ideas? :bigsmile:
The Dayton drivers are nice and very musical/accurate for the money. However I recently replaced my 390HO for a TC Sounds LMS-R 15". I wanted more 'feel' to movies - the excursion difference is 12mm on the Dayton vs 30mm on the LMS-R - so that swap was to move more air and keep musicality. I'm still dialing in the new driver, should have some better feedback soon.
The LMS drivers obviously look great on and off paper but not sure about the higher price if going with duals.
If only I had more money... :scratch:
So your question comes down to: is it better to build one 15" servo sub, or two 15" regular subs.
And that covers a whole lot of complicated.
So, let's start with this question: can you hear the difference between the servo subs you've heard and the non-servo subs you've heard? Because if there's a huge difference in your experience, then that will be your answer. If not, then given your budget, would you rather have 2 subs, or 1? 2 offers all sorts of advantages, but WAF isn't usually one of them. A pair of well designed Dayton 15s would serve your system proud, and provide a more visceral experience than 1 15 could, but not if what you hear is mud to your ears (go back to question 1). This all comes back to your personal preference- which sound within your budget do you prefer?
Tom
So your question comes down to: is it better to build one 15" servo sub, or two 15" regular subs. Tom
That is my dilemma. I will say I have never heard a Rythmik servo sub but from all the reading I have done they do seem intriguing.
Yellow is a Rythmik in 3 cu. ft. Green is a pair of 390HO's in 4 cu.ft. Building two cabinets each 2 cu.ft. for the 390HO's would allow you placement options for evening out the in room response.
Thanks Mike.:T Would the Daytons do better in a bigger box like the one I drew up for the rythmik?
I drew it at 17Wx19Hx24.25D which comes out at 3.45cu.ft. before bracing and driver. I was trying to make the smallest "Front" I could and still have a taller than wider look.
I would like to have duals just for the room response.
Discussion Starter · #10 · (Edited)
I have downloaded winisd and am trying to learn the program. So far I have added the 390HO and 390HF.
Looks like the HF might be better in 3.5cu.ft.?
The HF does better in a larger cab than the HO; you've got it right. The HO handles higher power- PE was honest in their descriptors about the HF and HO; the HF for better articulation for music (thinner, lighter cone), the HO for home theater and movie sound-track abuse (thicker aluminum). Again, design for your real use and taste. I personally went for the HF, since the number of times I'll crank up a movie, and test the limits of the system, is nil. But as the wiser guy said: your mileage may vary.
I agree that the write-ups on the Rythmics are intriguing, and I've never heard one either. I'd like to, so build one, won't you, and invite me over!
Tom
Maybe I should rethink this(due to my lack of subwoofer knowledge) by asking a different kind of question.
Lets say I want...
2 sealed boxes
15" drivers
No bigger than 3.5cu.ft. each
Somewhere around $800 for amp/drivers/eq, not the box.
60/40 music/movies
Room 3,900cu.ft. listening at moderate levels
What would you Subwoofer Guru's do?:help:
Ok so after cutting out some cardboard boxes at 3.5 cuft the wife says no way...:sweat:
I have been looking around and found the FI Q15 and the website says 2-2.5 cu.ft. which sounds strange?? am I reading that right? I put it into winisd with a tc sounds 15" and came up with this at 1500 watts, 70liters.
Does this look right?
106db at 20 hz is not to shaby for a small sealed box right?
It looks about right; but note the much lower Q on the TC system. These 2 will definitely sound different (not better or worse), and will appeal to different tastes.
Discussion Starter · #15 · (Edited)
When I get the Qtc closer to .707 I end up with 5.5 cu.ft. If that is a better Qtc why would FI recommend 2-2.5 cu.ft.?
Discussion Starter · #17 ·
Due to the fact that this thread has changed couse I am going to stop posting in this one and start a new one in the sealed section. :dumbcrazy:
1 - 17 of 17 Posts
