How much larger of a value would you go with then on the Rythmik plate amp?For a subwoofer amp I think it would be pretty pointless to simply swap to another type of cap. I do agree that a larger value filter caps could be beneficial though.
I would try and double the stock value.Keep in mind that the caps would be physically larger so be sure they will fit in the alotted space on the circuit board before purchasing.(Companies like Digi Key usually list the dimensions of thecaps they sell).Also the voltage of the replacement capacitors should be the same or higher or elseHow much larger of a value would you go with then on the Rythmik plate amp?
