1 - 18 of 18 Posts
http://www.samsontech.com/products/productpage.cfm?prodID=1699
This can be easily found on the net and also in some retail stores (I bought it locally at Sam Ash). It is usually $49.99. I haven't opened it up yet, but if someone would like me to, I could. I decided to measure the low end FR of it though, to compare it to the more common ART Cleanbox. Judging the results, I think it is superior out of the box.
I've indicated the -3dB point, which is 6.8Hz. The -2dB point is 9Hz and the -1dB point is 13.6Hz.
-1dB = 13.6Hz
-2dB = 9Hz
-3dB = 6.8Hz
-6dB = 3.7Hz
-9dB = 2.2Hz
I personally think that is just fine and a mod would be unnecessary. What do you guys think?
I think that the ART may have met it's match. That roll off below 10hz looks fine to me too. I can live with -2db at 9hz. To bad we didn't know about this before Christmas, it would've made a nice stocking stuffer!
Has anyone else bought one of these? How's the input sensitivity matching consumer/pro versus the CleanBox?
Don't know of anyone else on the forums that has one. But hey, if you want one I'll sell you mine. I don't need it anymore.
I recently bought one of the s-convert bump boxes for my EP4000 amp. It works great, the output from the dual subs measured nice and clean to 20hz. In fact -0.2db at 19hz so I am happy. The level of output was sufficient once I cranked the dial on the s-convert all the way up.
That is the reason I use the Samson with my EP-2500 and 2 subs. I heard a few months back that there was no mod necessary. Sorry I didn't mention it but I thought people here knew already.:doh: It works very well and I get full power out of the 2500. I am running 2 diy 12'' subs, one is a 1.0cf sealed box with the ED 13ov.2 and the other is a 4cf sealed box with the Shiva x. I run the Samson wide open, my recievers sub level at 0.0db and my 2500 at 1/4 gain and it is more than enough.
i just baught one and hooked it up, this is what i did, line outs from preouts to ins of sampson using rca, then outs of samson to my amps also using rca, is this correct or am i doing something wrong becouse when i did it this way i get no sound at all
Super Moderator
Using nothing at all, if possible. These things add noise to the system (at least if you’re using them for the main channels), and there’s a good chance you don’t even need it. I’d suggest reviewing Part 7 of my gain structure article (you can find the link in my signature). I’m sure you’re looking for an inexpensive solution, so if you really want/need one I suggest finding a used S-Convert. The only alternatives I’ve come across cost in the $200 range.
i have a crown xls 2500 for my DIY sub but my pioneer elite receive sub out put I'd only 335mv the crown needs 1.4v that is why I need a convert right will a art clean box work?
Super Moderator
Is that the output voltage you actually measured, or what Pioneer specs? Often the manufacturer’s figures are grossly under-rated.
The ART suffers from a mild low freq roll-out , so it might not be what you want for a subwoofer. See here. I think somewhere on this Forum there’s a thread about modifying it, if you’re brave enough to tackle that.
That said, it’s down only 5 dB or so at 20 Hz. Unless your sub digs below 10 Hz, that could easily be fixed with an equalizer.
I opened up my s-convert and many bad caps including ones in the power supply .I replaced them and the s-convert works great .
So guys if you have the s-convert open it up and check your caps .
cdx,
How did you go about checking the caps? My S-Convert has one channel that is much noisier than the other.
JSS
1 - 18 of 18 Posts
