G
Guest
·Hello I am having a problem that I found is a little bit different from others in the forums.
I have a HL-5067w samsung that I bought used, When I go to turn the TV on at times it just flashes the lamp light and go through it's reseting 3-5 times then just turns off. I have taken the bulb out and looked at it and it seems fine. When I put the bulb back in it starts right up but maybe 1-7 days later it will do the same thing so I take the bulb out look at it and put it back in and it works. Any ideas of the problem or do you need more info?
Thanks for the help in advance
