1 - 2 of 2 Posts
K
Guest
While watching the tv one day I heard something that sounded kind of like glass breaking and then the colors on the TV went crazy. Also When the TV turns on there is something spinning inside that seems to be either off center or part is broke off and vibrates pretty bad. O and I get no picture at all now when turning the tv on now.
I have removed the lamp and it seems to be fine so my next guess was the color wheel. Anyone have any suggestions. Does my guess sound wrong feel free to let me know if I have something wrong here. I know a little about my TV but not enough to troubleshoot it wholly. Thanx.
Plain ole user
Re: Samsung HLR5067 wax/xaa problem with color wheel I believe. Need help on removing the color whe
Likely a color wheel, also perhaps a light tunnel. Both are common failure points in Samsung DLPs.
1 - 2 of 2 Posts
