Hi, Room eq wizard is great software.
Is it possible to save the windowed impulse response. File->export->impulse response as wave just saves the raw impulse response. Also after using the minimum phase controls on the impulse reponse, is it possible to also save that as a wave?
Best regrads
Albert
+1
I too would like to be able to export an impulse response using the generated minimum phase info.
I have added the ability to save either the original or min phase impulse, with or without window applied, for the next release.
