1 - 8 of 8 Posts
So I had a thought, with the surface of a screen somewhat rough. Over time would this not collect dust on the surface causing some loss in the gain of the screen material? How does one clean this off? Vacuum, duster or some other method?
I'm no expert, but I would imagine a soft-bristle vacuum attachment used regularly would work great. Probably dedicate it to just that task so it would stay clean.
I just use a soft cloth dampened with plain warm water and I wipe it down once a week. It only takes a few minutes and since my screen is about 8 years old and still looks great I haven't found the need to try anything else. I did have this link in my favorites that has info on how to clean different screen materials that may be helpfull to someone. http://www.screeninnovations.com/faq/how-to-clean-your-projection-screen/
I cannot recall how long I've had my Elite, but I've never cleaned the screen material itself. It doesn't catch dust or anything like that. The frame, on the other hand, has to be vacuumed occasionally. Dust does gather there.
HTS Senior Moderator
I clean my AT screen every 3 months..It's not just dust that accumulates, it's also vapors that can enter when the door is open and if your theatre is near the kitchen (as mine is) then the build up can happen fairly quickly..
I generally use a dampened cloth with warm water and a very small amount of detergent..It gets rid of any grime on the screen..
I recently wanted to clean my screen, so I contacted Grandview and asked:
1. Does it matter in which direction I wipe to clean?
2. Can I use a soft dry cloth to dry the surface, or should I let it air-dry?
They replied:
It doesn't really matter which direction, dry with cloth is probably better
Not to use too much water though
The most important thing is not to use abrasive chemical as it will deteriorate that section of screen colour from its original colour
Make sure you do not use any tissue paper/ paper towel that leaves fiber behind,
Make sure that you do not use too much pressure to "push/ press/ poke" the fabric as it is very soft and fragile
Unless you have some stain on the screen, otherwise it should be just dust, Then you can just use a microfiber cloth or like Mr Clean disposable floor sweep cloth
So I took the screen off the wall and lay it on the ground. Using a soft damp cloth (lukewarm water only, then wrung out), I gently wiped the screen across its width. Then I used a soft dry cloth to gently dry the screen the same way.
And then I hung the screen back up. Nice 'n' easy. :)
1 - 8 of 8 Posts
