Searching Equalization That's Digital in / Digital out
6494 Views 30 Replies 6 Participants Last post by  Audioguy
This will be a rather longer post to give some background.
In a nutshell, what I'm seeking is alternatives to the miniDSP DDRC-22D. I have nothing against the DDRC-22D, but usually I like more than one option when considering a purchase.
If you choose to read further, I would appreciate any comments on what I'm about to say. I need to know that I'm getting this more or less right and where there might be weak points in my pursuit of audiophile music reproduction on a Honda Civic budget.
My 2.1 audio setup has a NAD C390DD 'all-digital' amp at it's core. The signal path I'm currently using is:
Digital source > Raspberry Pi w/ MusicBox > HiFiBerry Digi+ > MiniDSP nanoDIGI > NAD C390DD > Axiom M80 x 2 + SVS 12 sub
I've been experimenting with REW to do room EQ with pretty good success. The C390 has 6 EQ filters at fixed frequencies ranging from 40 hz to 240 hz each -12 dB to +4 dB. Using REW, I set those filters as REW specified with a crossover at 70 hz (I think) sweeping 20-300. Then I did a second run of REW to calculate parameters for the nanoDIGI sweeping 80-8000. The nanoDIGI has 5 parametric EQ parameters. I used that sample to generate 4 configs for the nanoDIGI having house curves of -1.8, -2.0, -2.2 and -2.4 dB/octave.
Here's where I've arrived, showing the 2.2 dB/octave setting.
Text Font Line Screenshot Software
I like what I'm hearing, but I don't have much experience with this room EQ activity. I think if I am to pursue room EQ beyond where I am now, I will need more and/or better matched filter options than I have now.
From what can see, people who've been doing this for years would have been in the analog domain until the equalization stage where they would use say a BFD to go analog-digital_EQ-analog and on to analog amplification.
Obviously with my setup, I stay digital throughout and don't want to (nor can I) drop down to analog just to match the inputs to an EQ.
I think the miniDSP DDRC-22D is one device that would serve.
Does anyone have experience with the DDRC-22D that they would like to share?
Does anyone know of alternatives to the DDRC-22D?
Thanks for listening. I look forward to comments.
Happy Holidays All !
Tim
1 - 20 of 31 Posts
I have and use the DDRC-22D. I reviewed it and also reviewed the nanoAVR DL. I also have the PC version of Dirac Live.
The digital in/out devices are my own preference for the same reason you have chosen, to avoid unnecessary AtoD and DtoA conversions.
The Emotiva XMC-1 with the +$100 adder for Dirac Live Full, is an alternative, but it is not inexpensive.
I am using the Behringer DEQ2496 mastering processor that has digital-in and digital-out input/output.
The DEQ2496 has 31 1/3 Oct graphic equalizer and 10 parametric equalizers per channel.
Both the graphic and parametric equalizers are working in conjunction
My method is using the REW measurements data to create manually the DEQ2496 graphic and parametric filters the following way:
1. Equalizing SPL curve to target curve with the 1/3 Octave graphic equalizer
2. Create narrow (~1/10 Octave) parametric notch filters with the parametric equalizer for suppressing room resonance.
I achieved excellent sound this way in my small listening room that has some acoustic treatment and its size is 3.3x3.3x2.4 meters (WDH)
See my system layout in below diagram including howto connect the measurement microphone for REW measurements.
Just adding - in your case you can connect the digital output of the DEQ2496 to your NAD C390DD amp who has optical input.
Thank you 'bertadora' for that advice. I will certainly look into the DEQ2496.
May I ask why you stuck to using an EQ with digital in outs? If you get a Yamaha YDP 2006 EQ (one of the very best made) and place it just before the amp you will get the same or better results for less money.
1. The reason to use DEQ2496 Digital out is to be able to use high end D/A (Grace 902) and not to use the internal DEQ2496 D/A that is good but not as Grace 902.
2. The Yamaha YDP 2006 EQ has only 6 parametric EQ per channel vs the DEQ2496 has 10 parametric EQ plus 31 graphic 1/3 octave eq.
I am using all 10 Parametric filters for suppressing my room resonances and the 31 Graphic EQ for SPL to target curve equalization.
The REW has a "find resonances" feature that find the measured room resonances and provide each resonance its center Frequency, it gain and T60 decay value in ms.
See REW help
http://www.roomeqwizard.com/help/help_en-GB/html/eqwindow.html#top
Not to steer this off topic but it seems that some room treatment would be a better option for you. Using as many filters as you are is not going to give you great results. In my experience the difference in most DAs is negligible.
I'm not sure to whom your question is addressed, but for me the reason I want an all-digital EQ is that I'm arriving at the EQ stage with digital output from the Raspberry Pi and I am needing to feed digital content as input to the NAD C390DD amp. My entire signal path is digital. To quote the description on NAD's website:
Like the M2, the C 390DD has no analogue stages in the signal path, keeping music in the digital domain right up to the speaker outputs.​
If Joe Walsh is an
I am Digital Man (first worked with a computer in 1967). :whistling:
You are probably right that some room treatment might be warranted. I'm still working to understand my system's interaction with the room.
Tim
Tim
Weather you keep the signal digital or not is not important if your already analog at the amps inputs putting the EQ just before the amp will give you the same result.
I believe what the OP is saying, if I understand correctly, is that the path is completely digital up to and into the power amp, which is digital with a digital input, and the power amp output stage itself is the system DAC, the first and only point where the signal changes to analog. And that he would like to accomplish the EQ without adding unnecessary conversion stages.
It can be argued that added conversion stages could probably not be detected audibly. He simply does not want them. In his shoes, I might do the same. Sometimes we make a purist choice like that on principle. Would he hear those extra conversions? Highly doubtful. But if they are not even in the system, then he will definitely not hear them.
The suggestion has been made that room treatment would probably make highly audible improvement in the sound at a fraction of the cost. This is no doubt the case, and remains a suggestion for the OP to consider along with the room correction that he chooses.
In a small listening room with size of 3.3x3.3x2.4 meters (WDH) there is a space and aesthetic limitationד of how much acoustic treatment you can apply.
I have absorbents and bass traps in the room, it improves the sound but not solving completely the problem of room resonance and early reflations.
The DEQ2496 with filters created from REW measurements provide a full solution in listening position together with the acoustic treatment. .
I don't think you're getting the point ... my 'amp' is actually an integrated DAC/amplifier. Even the amplifier section is digital. E.g. when I adjust volume, it is done in the digital domain. The 'amp' has no / zero analog inputs and the only analog outputs are the speaker terminals. Here's a pic of the rear of the amp. Electronics Audio equipment Electronic device Technology Audio crossover
The RCA plugs are SPDIF input/output and sub out. Equalization has to happen inside the box or in the digital domain before the box. That is why, I assume, NAD includes Room EQ adjustments within the amp at 20/40/90/120/180/240 hz. Each of these points can be adjusted -12 db to +4 db and either "wide" or "narrow".
As I said in my original message, I am liking what I'm hearing, but I don't have much to compare with. I am still learning about room EQ and REW.
My question about all-digital EQ devices was simply to gather information about alternatives. Two replies so far have provided suitable alternatives; the miniDSP device and the Behringer.
Wayne, you are correct in all you say.
Perhaps a bit of history can illuminate my situation. When I heard my first CD in about 1983, I decided that was it for analog for me No more ticks and pops despite all my caution with discwasher cleaning and keeping LP's in their sleeves. I kept my LPs, but bought CDs thereafter.
Until about 2 years ago, I had a NAD 7000 playing CDs and driving my Axiom M80's. Then a friend mentioned FLAC files and DAC's and that started me down a new path. I ripped all my CDs onto a NAS using JRiver media center on a PC. And I began to purchase High-res music downloads and look at streaming.
But to play this content, I needed a DAC. My NAD 7000 was also a bit long in the tooth by this time. As I looked at DACs, it became apparent that I was going to need to spend significant dollars. (Significant for me would be about $500+. I cannot even contemplate $10k speakers).
While researching DACs I came upon the NAD C3990DD and ultimately walked into the local dealership and told him to order me one. I don't think he knew exactly what I was getting, but it arrived.
I don't regret my purchase. The performance of the C390 is flawless. But it is true that with it I have the same disadvantage that comes with integrated amplifiers ... I cannot get into the DAC-Amp connection because it's inside the amp.
NAD provides EQ adjustments in the C390 apparently to tune the sub. But that won't let me do things like a house curve or tweak frequencies above 240 hz.
Using the nanoDIGI before the amp to do some EQ and adjusting EQ within the amp I have a pretty decent sound I believe. But I don't know how to determine that I have reached the best sound I can get. I have never had opportunity to listen to really high end audio; I simply go by what reviewers say with a grain of salt when it comes to things like interconnects and digital jitter and speaker wire and fancy power cords.
Tim
There seems to be a lot of comments on the Internet about the DEQ2496 overheating. Have you had issues with this? Did you add heatsinks for example?
Very wise.
I am aware of no economical alternatives to the miniDSP units for DSP / room correction / Dirac Live. Preamp solutions, like the Emotiva offerings, are great but higher dollar range. For 2-channel, I think the DDRC-22D is your best choice.
miniDSP offers 2 basic Dirac Live engines, the 48 kHz engine in the nanoAVR DL and the 96 kHz engine in the DDRC series.
I have the DEQ2496 from 2006 and have a friend that has it from 2006 too.
We never had any issue with heating of the unit.
Please note that we use it in listening room as a stand alone unit and not in a hot consul rack with other equipment like high power amplifiers that are running hot and poor ventilation like in DJ or recording studio racks.
Since you seem to be into manually setting up your system using REW, I’d agree that the DEQ2496 should be a good option for you to keep a digital signal path up to the amplifiers. I don’t see the point to shell out for the DDRC-22D unless you’re looking to switch to an auto-EQ solution.
That NAD looks pretty sweet – no doubt what pre-amps and integrated amps will be in the future. :T
I’d say look at how their systems are physically set up. If they’re stacking multiple DEQ units, putting them on top of amplifiers or in enclosed racks, that’s probably the problem.
I’d agree with Tony that you may be over-doing the equalizing. Very few (if any) rooms are ever going to have ten legitimate resonating frequencies. One or two is typical, along with some other peaks and troughs that aren’t true resonances or nulls. No system I’m using YDP2006’s on is using more than 6-7 filters combined for full range (i.e. separate EQs for mains and subs), so 10 filters for the subs alone is - yikes.
I’d suggest reviewing my Minimal EQ article, at least the sections titled “How to recognize useless filters” and the first section of “Tips for those using REW’s auto-EQ function,” which debunks the notion of equalizing for the best time domain results. Sure, it’s just one guy’s opinion, but a good number here have reported back that they got audibly better results “going minimal” compared to their previous tact of EQing to the max. No one has yet to report the reverse, that they got better results plastering their sub with multitude of filters compared to general smoothing.
One more vote for minimal EQ. Ditch the graphic, minimize the parametric, or go with just 3 or 4 parametric - on the worst peaks - plus Dirac Live
1 - 20 of 31 Posts
