Hi all.
Someone recommended I post pics of my HT construction.
We're currently building our new home on the South Coast of NSW, in Australia. The house is almost finished now. Currently the HT room is painted, but awaiting carpet etc.
See attached pics for some basic construction pics and also a mockup I did in photoshop of the front wall of the HT. Sorry for the quality of the photos, it's really hard to get a shot inside the HT room without a wide angle lens.
My HT set up will be the following:
Yamaha RX-V3800 receiver
Energy Conoisseur C7 floorstanders for mains
Energy center
4 x Athena bookshelfs for surrounds (surrounds slightly bigger than rears)
130" EVO 3D 16:9 screen from OZ Theater Screens here in Australia
Epson TW5500 (when it's released in a few weeks) (called the 9500 or something in the USA?)
The room is 4.4m wide x 5.4m long (14.43' x 17.71' for you yankees) with a standard 8 foot ceiling.
The subwoofers are 2 SHIVA mkIII subs that will be transplanted into bigger sealed boxes. They're currently in teeny 13" cubes with 600watt plate amps and relying on large amounts of EQ from the yamaha receiver - which I hope to do away with when transplanting to the bigger boxes (same plate amps tho). I need some help on how to fill the subs and what to fill them with to give deeper extension, so anyone with advice on that, I'd love to hear from you.
I'll be adding bass traps/absorbers around the room bit by bit after I get the audio gear in. The intention is to start with some front corner bass traps and some panels at the first reflection points and behind the mains. From there, depending on how much more i need, I will add rear corner traps, a couple of panels either side and behind the listener, and maybe 1 on the roof. But that may be overkill, so I'll see.
So that's it. It's nothing really super custom. I mean the room is a room, with rockwool insulation in all walls. There's 6 x dimming halogen downlights. The roof is matte black, as are all the window/door frames and architraves. The walls are all dark brown, with the front wall mixed between dark brown and black. There's 2 small, short windows at the back of the room, and 1 on the left wall, which will be covered with block out curtains. Carpet is dark brown.
Also ordered the chairs, which are 2 x leather recliners and a matching 2 seater leather couch.
I'll be posting more pics up over the next few weeks as bits and pieces arrive and I start adding things into the room, building the traps, the sub boxes etc. I know it's only a modest setup, but still is more than I have ever had before!
Would love to know what you think!
Cheers,
Scott
Energy center
Cheers,
Scott
