1 - 5 of 5 Posts
Hi there,
I am trying to send my filters to the BFD I have using REW. It comes up asking L or R, I click L, then it sends them no problem but when I another measurement its the same and hasn't changed.
Where am I going wrong?
cheers
graham
John,
I have the 1100 model BFD and I set it up as the 1124 model on the BFD itself and it all seemed fine.
I can send the filters to the BFD as I got a progress bar, but there was no red store button flashing to add it. I did try and send it to no 1. Should it have been no4 as it states on the BFD help guide.
This is the link to my diy build with my manual graphs with REW. What can I do to improve it?
http://www.hometheatershack.com/forums/diy-subwoofers-sealed-ported/21098-new-diy-sub-13.html
I have
cheers
Graham
The Midi protocols differ from 1 model of BFD to another, you will need to enter the filter settings manually.
1 - 5 of 5 Posts
