Hey guys, I have a Samsung UHD 4K QN65Q7FAM TV, Samsung HW-M550 Soundbar w/sub and a Samsung UBD-K8500 Ultra HD 4K Blu-ray player and what’s the best way to set up the sound, Bitstream or PCM? So far while watching all my streaming apps from my Apple TV 4K, the sound is pretty good but what I’m more/less interested in is which audio settings on the TV and especially which settings on my Blu-ray player. Still trying to figure out how to get that matched sound where the dialogue isn’t so quiet and then the action scenes blow you out of your chair.
On my TV, whether I select PCM or Bistream, the only options I have for the digital output audio format is either PCM or DTS Neo 2:5. Oh, and I’m using an HDMI cable between the TV and the sound bar for the ARC connection.
My Blu-ray audio settings are as follows;
I currently have the digital output set to PCM because the other three options are bitstream unprocessed, Bitstream re-encoded DTS and bitstream re-encoded Dolby D which I’m assuming is Dolby digital but I don’t know which one of those to use so being that I’ve got the TV audio set to PCM, that’s what I have the digital output on my Blu-ray player set to as well.
As far as the PCM down sampling, that’s always been set to on because that’s what the default setting is but I don’t know whether to turn that off or not because I don’t know if my sound bar is 96 kHz compatible or not.
I’ve got the dynamic range control turned off and I have the down mixing mode set to surround capable. Would that be better set to just normal stereo since I’m using a sound bar or just leave it on what it is which is surround compatible?
Thanks guys.
Thanks guys.
