1 - 3 of 3 Posts
HI guys,
I am looking to get one off these and there's a guy I know who wants to know the same.
I figure that I just use rca leads but would like to know what settings like gain etc.... I need to put it on.
Also what is the best way to wire it up. Do you connect a rca from the receiver to the -10 input on the samson and then run a XLR lead from the +4 output on the samson straight to the EP4000.
Do you need male to male XLR or male to female XLR.
Some advice would be really appreciated.
cheers
Graham
The way you explained the hook up is correct and I would start at halfway on the gain and then adjust as needed.
1 - 3 of 3 Posts
