141 - 160 of 947 Posts
Installed the unit today. Neither remote worked at first, but now the little IR one turns the unit on, although it turns itself back off seconds later. It comes on as ROOM2 SET >Room2 = OFF, then goes back into standby.
Hooked my universal player up, played some 2 channel. Some info was missing like the AVR was in multi channel mode. I had to use the front panel controls to get anything done.
I believe the little remote is only used for "Room 2". It does not seem to do anything for the main listening area (as far as I can tell).
In order to get the big remote to control the unit, make sure to press the "AUD" button on top so it says "Audio" in the display. Really, the remotes are the biggest downside to this unit - they are really, really poor IMO.
Discussion Starter #145
Ive abandoned my 972 remote and i use my Harmony 880, works just fine with that.
Remote is working, thanks! Set the CD to multi channel, it seems to be playing proper 2 channel now.
Doesn't want to switch inputs, but I'll figure that out tomorrow. I have a lot to learn. I know... read the instructions. :dumbcrazy:
Discussion Starter #147
its a little quirky as far as the front panel input is concerned. Im starting t understand how it works but still a bit of a learning curve to it. In the video input settings there are alot of options as to what it defaults to.
Hello,
The Remote Control was the main issue with this AVR and I pointed this out on the "I Got a New Toy's" first Post. I have been remiss that I have not mentioned this more, but the value is so good and Trinnov so exceptional that I have lost sight of this issue.
J
CD in Stereo mode, my mains do not sound as good as before. While the Newcastle does sound pretty good, I am missing the clarity of the Exposure integrated, the highs are subdued and the image isn't as specific, less air around the performers. I feel the sound does improve after 10-15 minutes of play (warmup).
My subs do sound better, the Dayton SA1000 is liking the LFE feed. Haven't played with the settings, levels or XO FR. I am tired and just want to listen to music. Looking forward to tweaking settings and running Trinnov.
Discussion Starter #151
Have you not run Trinnov? thats why it sounds so flat trust me it will sound far far better after you run Trinnov:T
I am counting on that, Room EQ is the whole reason I undertook this experiment. High tech AVR vs. minimalist audiophile amp.
I will run Trinnov this Friday. Work drains me during the week, and I will have that day off paid. It will be fun.
I am curious, I browsed around the manual, but didn't find XO points for the mains and subs. Just running straight Stereo mode.
I really am looking forward to reading your insights. It truly is best to run Trinnov when you have the time to do it in the best possible way. I was honestly shocked just how much a difference using a Tripod was as opposed to using Pillows to approximate Ear Level.
I wonder if there is an adapter that would allow me to attach the probes to my mic boom stand? I understand that the probes need to point upward and the dot goes to the front.
It is essential for the Microphone to be orientated correctly. I simply used Velcro Tape to place the Microphone to the Tripod.
Well I just jumped in and purchased a R972, This will be replacing my old Onkyo 805 and I will be running it in 5.1 for now. I have been reading about Trinnov for years now and even though I was hoping to get it in a new preamp with XLR outputs I just had to jump on the amazing price A4L had it. I should have it in a few days and will report back once I get everything setup :)
Hello,
With a 3 Year Warranty and it now being $1250 off the MSRP (actually that is for the Open Box 972's/$1200 off MSRP otherwise), this is truly an absolute steal. I personally use my Onkyo Remote to control the 972 as the Remote is absolutely pathetic on the 972. That being said, the Onkyo RC from the 805 can easily learn all of the important functions of the 972.
Cheers,
JJ
I agree, I don't see how I could go wrong with with this for $600 (plus the bonus end plates) I use a Harmony 880 remote so I doubt I will even use the factory remote beyond doing the initial setup.
Does anyone know if the owners manual is available online? I would like to read through it before I get the receiver but it looks like Sherwood totally dropped support for this thing including the manual :huh:
Also are there any firmware updates available for this receiver?
Discussion Starter #160
Manual is here, If your buying it form Accessories4less then it will have the latest firmware already installed.
