101 - 105 of 105 Posts
Discussion Starter #101
not sure about the stuffing and how it plays into the volume, but the internal volume by my calculation minus driver, amp, and brace was 6.35 cu ft.
Discussion Starter #103
double check the application notes included with the sub or perhaps start a thread here in the exodus section to get opinions. Kevin will surely chime in as will others if they believe your dimensions may or may not work. good luck!
If you look here at application 4.3 it will give you info on the Shiva build that is 5cf. http://web.archive.org/web/20041018205504/http://www.adireaudio.com/Files/VentedShivaApplications.PDF
Thanks, that's a very helpful document. Interestingly, 5cf is considered an EBS design with 18Hz tuning. After playing with WinISD I concluded that going larger would give me more output near the tunning frequency, but there's nothing terribly wrong with a box of 5cf or even a bit smaller. It's more important to get the tuning right for whatever size I eventually end up with. I'll probably end up equalizing the out of this thing anyway.
