I was the winner of the Shiva-X giveaway and just received the driver. Thanks Kevin! I also ordered 2 15" PR's and want to build the NeoDan end table design below. I have an EP-2500 for power and an SMS-1 for hpf and eq. This is my first build. I do have quite a bit of previous wood working experience but could use some help.
First off I need to gather all the tools and materials. I already picked up some 3/4" MDF for the cabinet and will be using a circular saw with clamped guide to make the straight cuts. I also picked up a Jasper 200 for cutting the circles for the driver and pr's. This design only has a single layer baffle for the driver and pr's. Should I consider using 2 layers to flush mount them?
Should I use screws or hurricane nuts for attaching hardware?
What speaker terminals work the best? speakons?
I need to buy a bunch of clamps. Any recommendations?
What else do I need?
Thanks,
Steve
Thanks,
Steve
