1 - 7 of 7 Posts
I need a comparison please. I am wondering how the shiva-x will compare to a def tech super cube 1? The shiva x will be in a 2.5 ft3 enclosure with a PR tuned to 20hz. The shiva x will be run with a 500 watt amp.
I am guessing the shiva x will have more output down low but how else do they compare in overall output, sq, and anything else?
thank you
i was going to use the 15" diycable pr unless there is a better pr i should look at out there?
Na that's fine
hmmm it's hard to tell they both are really good...But I'd still go with the Shiva since DIY is in most cases better then most audio places, and you could always build a better box for the shiva if you change your mind.
This isn't a fair comparison the Shiva would crush the def tech in a proper box and is much cheaper.
4.0cuft is the proper size for a 20hz tune of the Shiva.
1 - 7 of 7 Posts
