1 - 2 of 2 Posts
I got 3/4" MDF the other day for a shiva-x2 build, and I am about to start cutting, but before I do, I would like to have you guys review my design first, since it is my first DIY build.
I chose the shiva-x2 with 2 PR package for my build over a tempest-x2 build because I prefer a smaller box (~4.5 cu ft internal volume vs over 9 cu ft internal volume) over the ~3 db and slightly deeper extension.
The internal volume will be ~4.5 cu ft, with the driver, prs, and braces in place. The PRs will have 8 discs (making about 1000g I believe) on them. The amp will be the dayton 500w from PE.
Here are some pictures of the finished box and the winisd graph.
Any suggestions? Also, should I line the inside with anything?
Im not sure if you can see my pictures here, so here is my post in avs forum.
http://www.avsforum.com/avs-vb/showthread.php?t=1196610
1 - 2 of 2 Posts
