1 - 4 of 4 Posts
Running a Shiva X2 single 4ohm right now in a 2cuft box. Looking at getting more output and perhaps deeper extension. Would like to run it in one of the flat pack enclosures like this one http://www.diysoundgroup.com/ported-subwoofers-1/4-ported-sub-flat-pack.html I can't find any of the Shiva's TSparameters or pdf documents anymore since Exodus is not longer around.
Any Idea on port length for the flat pack and Shiva to go together? $110 for the enclosure to gain what I hope would be some more output.
Looks like a 22-25hrz HPF would be needed? Thanks for taking the time to model that. Any way you could post the TS parameters? I looked everywhere and couldn't find them unless I happened to glance over it.
1 - 4 of 4 Posts
