81 - 95 of 95 Posts
Discussion Starter · #81 ·
SUB legs
Box is braced 100% now I need to build LEGS!!!
SUBWOOFER legs!!!
should I just use scrap pieces of wood?:hsd:
sub shakes floor too much needs proper legs:hsd::fireworks2::fireworks1::storm:
Did you wipe off the stain?
You can very lightly wet sand before a second coat if you need to. Will this be a wet/high gloss finish?
Most of the time I dont sand at all until maybe a 3rd or 4th coat. But I let the poly cure after 3 coats. If applying the second coat within 2hours then I would not worry about sanding.
Parent approval factor haha, even when I was in my parents house with the wimpy bic f-12 they would rant about the volume saying it shook the pans upstairs. I can only imagine a 15 with 4 times the rms power. I'm pretty excited to get mine up and running.
81 - 95 of 95 Posts
