1 - 7 of 7 Posts
I thought I'd share a recent project in case it would be helpful for anyone else out there...
***** WARNING - This project involves working with 120V A/C circuits. Do not attempt unless you are thoroughly familiar with proper wiring and safety practices *****
I use a Crown CTs600 power amp to drive my HT subs. This is a pro-audio amp and it does not have a remote turn-on trigger. I wanted to have the amps power cycled on and off automatically when used. I have an Onkyo HTR that will switch the 5v power to a rear USB port and also a Yamaha HTR that has the traditional 1/8" 12v trigger ports which are even more useful in that they can be programmed to trigger with Main or Zone power, or even when certain inputs are selected.
I chose to use an optically isolated relay to ensure that the A/C power can never backup to the receiver in the event of a failure. This type of relay module is dirt-cheap. I purchased mine on Amazon and I'm sure eBay would be another good source. These modules require very little DC current to activate which was a bonus since I couldn't find any data on how much current the Yamaha 12v trigger port could supply.
Since 120vac power outlets are rated at either 15 or 20 amps, be sure and use a relay and wiring that's rated for at least that much unless you also intend to wire a fuse or circuit breaker in-line to ensure the load current never exceeds the relay rating. I used 30 amp relays. Here is a link to the dual 12v module that I used. I plan to use the second half of it to power another CTs600 for Zone 2.
Knackro 12v Optically Isolated Dual Channel Relay Module - http://a.co/bMKaqRl
For the A/C wiring, run your power cord ground and neutral wires directly to the outlet and the hot wire to the comon terminal of the relay and then run a wire from the Normally Open terminal to the hot side of the outlet. Zip-tie everything down.
Picture #1 - The 12v relay wired with the 1/8" trigger plug and ready to mount in the plastic electrical box.
Picture #2 - Completed 5v USB trigger box internal.
Picture #3 - Completed 5v USB trigger box.
Hope this is helpful to anyone needing to trigger power to a device that does not have it built-in.
Here's the completed dual-channel switch. Trigger 1 switches my sub-woofer amp, and Trigger 2 will switch a Zone 2 amp. Both connected to my Yamaha RX-A1070 HTR. Works great!
That's great! very cool.
also if you don't feel 100% good with working with high voltage THIS also works... but it's only 1 outlet as opposed to 4.
Discussion Starter #5
Oh, very good! I was not aware of a product to accomplish what I wanted, so I resorted to building it.
Could share your specific terminations made at the 12v end of the dual-channel relay?
(I'm attempting to duplicate your efforts for my similar project.)
Hi. I'm struggling to make this work. The AC connections are clear, but it's harder to tell from the pictures how the trigger connections are made. Am I correct that that the trigger wires are connected to DC+ and DC- respectively, with a jumper between CH1 and DC+? When testing with a 12v battery, the red light on the relay lights up, but I get no power.
1 - 7 of 7 Posts
