1 - 4 of 4 Posts
G
Not the first one I've built, but IMO the best looking, and the deco panel isn't even built yet!
Driver:
MTX Thunder 4000 12" 8ohm
Box:
Sealed
Downfiring
16mm MDF w/double thickness recessed baffle
Approximately 1cu-ft volume
Still to do is make a top trim panel to cover up the average carpet joins, which will be made out of pine and stained Baltic to match the speaker stands that are my next project. May eventually fit a plate amp if required, Panasonic has amp built in so wasn't needed up front (saving $$$!)
The wife approved (despite the joins!) and it's more than enough to shake the white ants out of our floorboards given the right soundtrack :) No idea what the final tuning is, but it goes low enough!
Any chance you can post a REW FR at LP?
1 - 4 of 4 Posts
