61 - 80 of 346 Posts
HTS Senior Moderator
Re: New basement HT Posting progress photos
It'll all be worth it soon enough. Hang in there. :daydream:
Bryan
Discussion Starter #63
Discussion Starter #64
Well the dry wall in mostly complete, he should start taping and muddling later this afternoon. I asked him hypothetically how much he would charge to pain the room, and he will now be painting the room for me, as I can't touch it for $125, I have to buy the paint obviously ;-)
I told my wife I was going to paint the ceiling black, and she said why not pain the whole room black ;-) Not sure I will like that but who knows it would save me from having to decide on a color LOL
Now I am deciding if I want to paint the walls a dark blue or dark red (black cherry). I am going to be putting in some new carpet as well. Currently it has a charcoal gray felt carpet, that was good for Min-Z RC cars ;-) and I had planned on just using that for now, but after the framing was done it was obvious that the carpet we going to be a pain to clean up, I should have taken it up before he started ;-)
We picked up the doors last night as well, I have a 32" steel entry door that has full insulation and full weatherstripping. I had budgeted $120 for a door, and I found this one for $88 at Home Depot, however it has holes for both a door knob and deadbolt, I wanted only a single home. So I bought a cheep deadbolt/door know set for it. We are installing it so the door opens outward from the room and thus is inset.
I am still not sure what to do about a stage and a rear seating riser. I don;t really have the funds right now not the seating so for now I suppose I will just wait for those. I do not have any real idea on what I want up front yet so I can add those later. As I have been told this is a never ending project so I guess I will just take my time once the main part is complete and I have a functioning HT.
You're lucky ... most of the time they don't want to even hear "dark color" :bigsmile:
I suggest you to take her and choose a color; or you can sit down and scroll through the forum for pictures and show her; it doesn't have to be black ... just a dark color to avoid the light reflection :yes:
I've seen blue, gray, green and of course my color burgandy :bigsmile:
Will you be using fiberglass to cover the whole front wall??? ... if you are, you don't need to paint it, just use speaker cloth or any transparent fabric to cover the fiberglass and you'll be fine. :yes:
If you have plans for a riser, maybe is a good idea to don't carpet the whole room (to me it will be a waste of money), it will look odd ... but Why you want to install carpet and then cut it and throw it away??? ... maybe is better to get some 2"x4"'s instead and start building the raiser little by little :dontknow:
Discussion Starter #66
Its been a couple days now and the drywall is prepped for painting, the contractor comes back this evening to put in the doors and spray the primer. The finished texture on the walls "orange peal" looks great and thus it required little to no sanding in most areas (he is a good mudder ;-)).
I have been running the dehumidifier in the room constantly so the area is kept very dry during this period so things dry evenly and quickly.
I have decided on my colors, please comment or recommend any thing that should be changed?
The ceiling and screen wall will be flat black. The side walls and rear of the room will be a dark Burgundy I think its called ruby quartz. It looks black when the lights are turned down low. It is flat as well.
For now I am going to pick up a piece of black "felt" carpet with no backing (it is similar to what had been down there at the start of the project, but in black) It has little to no reflectivity. I will have about 37'x12' of it so I could cover the entire floor with it but I am going to stop short of the back at 24' that should bring it from the screen wall to the equipment rack wall and leave me with severla feet left over. I am going to use carpet tape to tape the edges so I can pull it up later to build the stage and riser later on.
So in short, black ceiling, screen wall, and floor. dark Burgundy walls. I hope it looks nice ;-) more photos to follow soon.
I'm sure it will look good ... :yes:
Are you planning to kill the front wall with fiberglass??? ... that will help with accoustics too, and instead of painting the wall; you can use speaker fabric or any transparent fabric (black) :huh:
Edit: I know is not the same as using fiberglass, but I'm sure it helps (I did it on my HT) ... you can use ceiling accoustic tiles (http://www.armstrong.com/resclgam/na/ceilings/en/us/prod_detail.asp?itemId=45147.0 ) just paint them black ...
Discussion Starter #68
Are you planning to kill the front wall with fiberglass??? ... that will help with acoustics too, and instead of painting the wall; you can use speaker fabric or any transparent fabric (black) :huh
Reading back through the posts I think you asked that before but I was rude and never answered :duh:, sorry.
All the walls are pinked and t hen dry wall is that what you mean?
I am sure I will need some acoustical treatments throughout, and maybe a base tube?
I am planning a stage (small/short) and a riser in the future. Also have been toying with the idea of making pillars on either side of the screen and bottom to hid the speakers and subs.
Generally, in a multi-channel environment, the front wall is absorbtive for a couple of different reasons:
- Deal with bass response anomolies if the speakers are relatively close and avoid issues with SBIR
- Absorb reflections from the surround speakers so they don't reflect and mix with the front soundstage and blur the imaging.
You're also going to want a reasonable amount of broadband bass control as well as some way to deal with the side wall reflections.
Bryan
Discussion Starter #70
Based on what I have what would you recommend keeping in mind I have little to no budget left :sad2:
Find a supply house that carries 4.5lb mineral wool. That's probably the cheapest (though not the easiest to work with) material to use.
Make some triangular chunk style absorbers for the front corners and finish off the rest of the wall with some 2" covered in cloth. You can DIY this pretty reasonably.
Bryan
Discussion Starter #72
Where is Mineral/Rock wool usually sold? Home Depot or Lowes do not seem to carry it.
Try either your local insulation supply house or potentially a metal building supplier.
Where is Fontana?
Bryan
Where is Fontana?
Bryan
We're about 60 miles east of Los Angeles in San Bernardino County.
We have the famous California Speedway (I don't know if you like races, but at least twice a year they have NASCAR, Indy 500 or some of those popular races ... I'm not into that, so I can't tell :bigsmile:)
Well, closest KNOWN to you is
SPI
5301 Industrial Way
Fleetside Commerce Center
Benicia, California 94510-1026
707-745-4922
707-745-4987 FAX
800-359-3555
That'd likely be cheaper than shipping from anywhere else if you have to order it. I know they have what you're looking for though. Should be able to get 4 and 8lb. Should also be able to get 2" and 4" thickness in the mineral wool. I'm sure they run trucks to LA all the time.
I'm sure there are other places in the LA area that have it too - just a matter of finding them and what they'll charge you.
Bryan
Discussion Starter #77
Uhmm, I am in Bethalto, IL about 20 miles north east of St Louis MO. :huh:
Discussion Starter #78
More pictures!
Didn't realize I was that far behind! I have been busy! This has not taken very long considering most of the work has been done by one guy working about 5 hours a day.
... I'm sure there are other places in the LA area that have it too - just a matter of finding them and what they'll charge you.
Bryan
Bryan ... Carls64 lives in Bethalto, IL :bigsmile:
Doh! :duh:
Sorry about that. Looked at the wrong thing. Try:
Brauer Supply Co.
4260 Forest Park Ave
Saint Louis, MO 63108
(314) 534-7150
Ask for Liz in insulation. Tell her I sent you. She'll know what you're looking for.
Bryan
