1 - 3 of 3 Posts
Hello everyone !
I do not have experience in audio design.
I have a multimedia subwoofer from set Speedlink Mace 2.1 subwoofer system.
Dimensions of a box are w/h/d = 19 / 14 / 12 cm. Horn is 7 cm deep.
For my application I would like to make a box slimmer e.g. 7-8 cm depth. It is possible for box to be longer and higher. Also, I would like to have a speaker and horn on the same side.
Is a bass quality still fine? Does it work at all?
Any suggestion to make box slimmer?
Bye and thanks !
If your designing a subwoofer you can have whatever external dimensions you desire. So I am a bit confused what your wanting to do. Also there arent very many under 7" speakers that can be used as a subwoofer that are worth while building.
1 - 3 of 3 Posts
