1 - 4 of 4 Posts
I just plugged my ipod touch (4th gen) into my brand new Yamaha 673 receiver using a usb cable.
I noticed there is an occasional popping sound in the background, almost sounds like an old record popping sounding on a turntable. I googled this and found lots of folks having the same problem, due to not having the newest version of the ipod.
Is anybody else having this problem?
Also, do u think the sound is better going thru the USB port or using RCA left and right audio jacks?
Also, can anybody recommend a quality ipod docking station for use with an AV receiver
I agree a dock would be your best option however going from the headphone out into the RCA inputs would give the same result. I usually avoid the direct USB connection.
1 - 4 of 4 Posts
