Status
Not open for further replies.
1 - 5 of 5 Posts
A sweet sonic beauty of an amp designed by the legendary designer John Iverson. (Google: John G Iverson for an interesting read.) I have owned many different amps, both tubes and solid state, but this unassuming Plain Jane looking amp is the very best and continues to satisfy with rich textures and musical harmonics all delivered with renowned bass slam and authority. It's rated at 120 watts per channel, but this monster amp pushes a TON of current and has HUGE capacitance and can drive any real world speakers load with ease. Here are the general specs on the amp:
Output Voltage:
29.7 Volts RMS at 8 Ohms
Load Impedance:
Greater Than 1.5 Ohms Music
Peak Output Current:
40 Amperes Symmetric
Rise and Fall Times:
2.6 Microseconds Symmetric
Output Operation Type:
Class AB
Bias Current:
150 Milli-Amperes
Power Bandwidth:
DC to 120 KiloHertz
Damping Factor:
Greater Than 800
Harmonic Distortion:
.0025% Typical
Intermodulation Distortion: .0035% Typical
Signal/Noise Ratio:
90dB below 20 Volts Output
Input Impedance:
100,000 Ohms Resistive
4 PicoFarads Capacitive
Input Sensitivity:
1.0 Volts RMS For Full Output
Signal Phase:
Non-Inverting
Input Connector:
1 RCA Phono Female per Channel
Output Connector:
1 set 5-way Gold Binding Post
Filter Capacitance:
160,000 MicroFarads
Dimensions:
18"x10"x6"
Plain ole user
Re: Electron Kinetics Eagle 4 Prime - $750+Shipping
These are great amps. I don't need another amp, but if you decide to let it go for less I would give $450 for it.
Thanks for the offer. I'll hold on to it for that. Trying to generate some dough for an XPR-2 :).
Plain ole user
It is worth what you are asking, IMO. Nice solid high current amp.
1 - 5 of 5 Posts
Status
