I have two extra 15" JBL bass drivers that I’m thinking about sticking into a sonotube.
The design looks relativity straight forward and simple, just requires tools and patience in building it.
I have no idea where to obtain the tubing itself within the UK? I’ve fished around other forum sites and even a few in US have pick it for $35.00 (around £15.00) so I guess it’s cheap, I mean its hollow tube.
The Google link here where, oh, where is there a UK supplier?
http://www.google.co.uk/search?hl=en&q=where+to+buy+sonotube+uk&btnG=Search&meta=&aq=f&oq=
Also I was thinking of tubing that is used on roadwork’s as I have seen some yellow tubing that my dad says is used for gas. Blue water, and black he thinks fresh water.
Ether way this could be used, and often there are off-cuts lying around after the job has been done. I, might look at one works this week if, its still be worked on and providing they say it’s okay to take an off-cut as its only scarp.
I would like to do 12 footer twin tubes mounted close to ceiling corners to throw the lows out, would this not work (yes or no, or (maybe) as that is an option).
Also I see there is calculator on the site that can determine size for required sub bass diy projects, very interested.
Options gentlemen?
Options gentlemen?
