1 - 11 of 11 Posts
You should only need the optical cable connected to listen to an audio CD.
If you connect the CD changer to the top optical input marked TV and change the receiver source to TV it should work. You also may have to press the "Input Mode" button on the front of your Denon to set it to either Digital or Auto after the source has been changed to TV.
Let us know if you get it working.
I'm not familiar with that particular player, but video displays often provide more information about the CD and track that's playing than can be shown on the player's front-panel display. In other words, having the video cable connected can be useful.
Don't forget that your Blu-ray player can play CDs, too, although only one at a time.
1 - 11 of 11 Posts
