1 - 2 of 2 Posts
Hi you all.
I have a Home theatre sysmtem Sony DAV-SA30. It's very powerful. I realy appreciate the dynamic sound delivred by this system. Unfortunaly it does not have a digital or optical input. So I can only enjoy 5.1 surround sound in case I use the integrted DVD player. Even my PC has multi chanel output (7.1) I can't perform 5.1 sounding while gaming or playing movies in such dolby digital standard.
My question is : Is there a way to creat a digital or optical input for the DAV-SA30 ? If not I think I will finaly try to connect a wire of each analogue chanel to the specified circuit board parts.
Please tell me what do you think about it.
Any word from you will be helpful.
Thank in Advance !
HTS Moderator , Reviewer
Hi you all.
Thank in Advance !
I just took a look at your system. it's got a proprietary jack so there's no way to get analogue OR digital to it elsewhere. you'd most likely need a full receiver to do what you want. I honestly wouldn't go about connecting the analogue leads to your circuit board the way you were describing. Way too much risk.
1 - 2 of 2 Posts
