1 - 2 of 2 Posts
Set turns on , power/standby led blinks green several times,Then holds green for one second changes to red and blinks 7 times in sequence forever, no picture or sound. I believe the TV is turning on and then shutting down
Plain ole user
IIRC, 7x blink code on this set is an audio circuit failure. Check your supply to the audio circuits and the audio output IC.
1 - 2 of 2 Posts
