Please read the first ten posts of the convergence repair sticky in the DIY Repair forum VERY carefully.
http://www.hometheatershack.com/for.../5600-crt-based-rptv-convergence-repairs.html
Blown fuses occur for one of two reasons. Either something internal shorted and pulled too much current, or something on the source side created a surge and took out the fuse, with or without damage on the other side of the circuit. Because you have multiple supply lines with open fuses, I am guessing either a power surge or a failure in the primary of the power supply caused the open fuses. I would start by measuring the load side of the fuses to see if there is an obvious short to ground on one of the lines, and check the likely components that might be damaged in each supply circuit.
You can run these sets with the convergence ICs out of circuit.
