1 - 9 of 9 Posts
Would anybody know if there is a recall setting for the above CRT display? The factory settings in the service menu have been messed with and I was under the impression that there is a master reset in the service menu that recalls the factory settings. I know how to get into the service menu but just cant find the setting to do so.
Thanks.
Thanks Sonnie.
Plain ole user
There is a reset, but you don't want to use it except as a last resort. The default settings are not the same as they settings from the factory, which are custom for each set. The set will require a lot of re-alignment if you do a reset.
Thanks Leonard, Thats what I feared.
The picture quality looks good but the picture "convergence" is not even and when camera pans happen the image is strange as if its not perfectly aligned to the grid.
I have DVE and AVIA would putting up a grid and making adjustments in the service menu help?
Plain ole user
Is your problem with geometry or with convergence?
Yes, it is likely that you can make some improvement, but I would be very cautious and record all values and changes. Don't adjust anything that you are not sure about.
When I said "when camera pans happen the image is strange" I meant that the picture seems wavy does that make sense? I was able to get it close today, I spent about an hour in the service menu It seemed as if the Horizontal settings were off. My issue now really is just the red seems a bit out on the outside of the image the center is good. I'm assuming that its a convergence issue but cant find a convergence grid setting like in my Sony RPTV upstairs.
Its my understanding the Sony uses a single gun in there CRT displays?
Plain ole user
Convergence may require adjusting the physical position of the yoke or magnets. This is a very complex process that I would not recommend for a novice. At the very least, you need a copy of the service documentation for the process.
Ok thanks, I will leave well enough alone. its much better now anyhow.
1 - 9 of 9 Posts
