hi i have a sony str-de725 everything is working except for the rear right channel,switched another speaker to that channel an still no sound switched speaker back n speaker works fine.have been lookn around and im thinking output transistor.??did a visiual n didn`t c any obvious blown caps fuses or resistors thanks in advance 4 any help
A long burned up connection sounds like a circuit trace. Very rare for that to happen as it takes a lot of current. This is the kind of thing we see on ground traces in lightning strikes.
Well it happened again,the rear amp circuit board burnt again blowing a couple of fuses and this time taking out a power transistor with it.sony part#8-749-020-25(MN2488).I removed the rear amp board and receiver is playing ok on front channels.Should i replace the pair of power transistors(MN2488,MP1620)or just the one that blew?(MN2488)The cost is minimal about $3-$5 ea.How should i repair the board?Thanks in advance 4 help.Here r sum pics.
If the transistors are shorted, change them. I would be looking for a shorted speaker wire or something else wrong in the unit with that kind of damage. Shorted transistors in these will usually shut the unit down, maybe take out a fuse, but burned traces mean something else is very wrong.
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
