1 - 1 of 1 Posts
Hi
I have owned this since new, mid 80's. For the last little bit I have trouble turning it on or off from the physical front face button. The remote control is only able to turn it off. The button seems to be physically sitting unlevel in the face plate and often takes multiple pushes to work. Last night I sprayed around the button face with contact cleaner, in the middle of the night the stereo turned on two times?
I believe this is some sort of physical tactile switch, as the speakers come on about 10 seconds later when a relay clicks in.
Any thoughts as to what to look for.... the unit is perfect otherwise.
The photo shows the button crooked.
Thanks
1 - 1 of 1 Posts
