1 - 5 of 5 Posts
It's been a long time since I needed advice on doing home stereo choices for audio/video, so I thought I would start here.
I have both a JVC THD60 DTS (digital theater system) and JVC LT-46M51 46" TV. I mostly play stuff from Roku though the TV and once in a while, use the stereo system to improve the sound. More than anything, it is just a hassle with the outdated remotes I can no longer find and the bulky stereo that I no longer use anything but to play sound through from the TV. I had a JVC sound bar once. It was ****. I sold it a few years later.
Is there a sound bar with bass the allows for multiple device hookup? I would need to hookup the TV, Roku, laptop and a new addition for a while, a JVC VHS / DVD player (until we get all our VHS to digital) or JVC DVD player (to watch our DVD's on). So, 4 HDMI ports?
Yes, I liked JVC equipment, but it seems they went to the way side and don't offer a lot of products anymore. I buy Samsung stuff now when I can, ie: TV, cell phones, etc.
Any suggestions? My sister bought a Bose sound bar, $300 and was not happy with it. I am reluctant to use a sound bar, but maybe they have improved over the years since I last had one. My sisters issue could be something else all together.
Thanks!
HTS Moderator , Reviewer
Soundbars are not a category I have much experience with but when I hear that word Zvox and Sonos are the first names that spring to mind. Sonos can tend to be more of a "lifestyle" product, so they're typically a bit expensive, but they seem to be regarded well. Zvox are one of the original pioneers of the category so they've been providing solutions for a while. I've heard some positive things about Vizio and it seems JBL has a couple of popular offerings as well so perhaps those are 2 others worth considering.
Note that in addition to soundbars there is also something called a soundbase. Unlike a soundbar, which is a thinner speaker array that sits in front of a TV, a soundbase is actually much larger and more square allowing you to put the TV directly on top. A soundbase can be an adequate all in one unit as the larger cabinet dimensions allow for more bass and output (volume essentially). Always be a little leery though when you see "built-in subwoofer" as the physical dimensions of any soundbar/base don't allow for true bass. For that you would need a separate subwoofer.
Soundbars are not a category I have much experience with but.....
Thank you Jim for the feedback, it is informative and helpful and much appreciated. After I wrote the post, I started reading some of the comments about sound bars, which of course are just not that great compared to true sound systems.
Looking more at what I have and thinking I have a pretty good system still, just wish the wife would let me hang the speakers all over the living room! Oh well, it is what it is.
Note that in addition to soundbars there is also something called a soundbase. Unlike a soundbar, which is a thinner speaker array that sits in front of a TV, a soundbase is actually much larger and more square allowing you to put the TV directly on top. A soundbase can be an adequate all in one unit as the larger cabinet dimensions allow for more bass and output (volume essentially). Always be a little leery though when you see "built-in subwoofer" as the physical dimensions of any soundbar/base don't allow for true bass. For that you would need a separate subwoofer. snaptube vidmate word to pdf
Thank you jim
thanks for the awesome information.
1 - 5 of 5 Posts
